drivers/staging/usbip/userspace/libsrc/vhci_driver.c: test the just-initialized value
Test the just-initialized value rather than some other one.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@r@
identifier x,y,f!={PTR_ERR,ERR_PTR,ERR_CAST};
statement S;
x = f(...);
if (\(x == NULL\|IS_ERR(x)\)) S
*if (\(y == NULL\|IS_ERR(y)\))
{ ... when != x
return ...; }
Signed-off-by: Julia Lawall
Acked-by: David Chang
drivers/staging/usbip/userspace/libsrc/vhci_driver.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/usbip/userspace/libsrc/vhci_driver.c b/drivers/staging/usbip/userspace/libsrc/vhci_driver.c
index abbc285..2697877 100644
--- a/drivers/staging/usbip/userspace/libsrc/vhci_driver.c
+++ b/drivers/staging/usbip/userspace/libsrc/vhci_driver.c
@@ -133,7 +133,7 @@ static int check_usbip_device(struct sysfs_class_device *cdev)
strlen(vhci_driver->hc_device->path))) {
/* found usbip device */
usbip_cdev = calloc(1, sizeof(*usbip_cdev));
- if (!cdev) {
+ if (!usbip_cdev) {
dbg("calloc failed");
return -1;
- if (!cdev) {
return -1;
