drivers/staging/iio/adc/spear_adc.c: use clk_prepare_enable and clk_disable_unprepare
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Clk_prepare_enable and clk_disable_unprepare combine clk_prepare and
clk_enable, and clk_disable and clk_unprepare. They make the code more
concise, and ensure that clk_unprepare is called when clk_enable fails.
A simplified version of the semantic patch that introduces calls to these
functions is as follows: (http://coccinelle.lip6.fr/)
expression e;
- clk_prepare(e);
- clk_enable(e);
+ clk_prepare_enable(e);
expression e;
- clk_disable(e);
- clk_unprepare(e);
+ clk_disable_unprepare(e);
Signed-off-by: Julia Lawall
Reviewed-by: Viresh Kumar
Signed-off-by: Jonathan Cameron
drivers/staging/iio/adc/spear_adc.c | 25 ++++++++-----------------
1 file changed, 8 insertions(+), 17 deletions(-)
diff --git a/drivers/staging/iio/adc/spear_adc.c b/drivers/staging/iio/adc/spear_adc.c
index 675c427..0b83e2e 100644
--- a/drivers/staging/iio/adc/spear_adc.c
+++ b/drivers/staging/iio/adc/spear_adc.c
@@ -330,36 +330,30 @@ static int __devinit spear_adc_probe(struct platform_device *pdev)
goto errout3;
- ret = clk_prepare(info->clk);
- if (ret) {
- dev_err(dev, "failed preparing clock\n");
- goto errout4;
- ret = clk_enable(info->clk);
+ ret = clk_prepare_enable(info->clk);
if (ret) {
dev_err(dev, "failed enabling clock\n");
- goto errout5;
+ goto errout4;
irq = platform_get_irq(pdev, 0);
if ((irq < 0) || (irq >= NR_IRQS)) {
dev_err(dev, "failed getting interrupt resource\n");
ret = -EINVAL;
- goto errout6;
+ goto errout5;
ret = devm_request_irq(dev, irq, spear_adc_isr, 0, MOD_NAME, info);
if (ret < 0) {
dev_err(dev, "failed requesting interrupt\n");
- goto errout6;
+ goto errout5;
if (of_property_read_u32(np, "sampling-frequency",
&info->sampling_freq)) {
dev_err(dev, "sampling-frequency missing in DT\n");
ret = -EINVAL;
- goto errout6;
+ goto errout5;
@@ -389,16 +383,14 @@ static int __devinit spear_adc_probe(struct platform_device *pdev)
ret = iio_device_register(iodev);
if (ret)
- goto errout6;
+ goto errout5;
dev_info(dev, "SPEAR ADC driver loaded, IRQ %d\n", irq);
return 0;
-errout6:
- clk_disable(info->clk);
errout5:
- clk_unprepare(info->clk);
+ clk_disable_unprepare(info->clk);
errout4:
clk_put(info->clk);
errout3:
@@ -416,8 +408,7 @@ static int __devexit spear_adc_remove(struct platform_device *pdev)
iio_device_unregister(iodev);
platform_set_drvdata(pdev, NULL);
clk_put(info->clk);
iounmap(info->adc_base_spear6xx);
iio_device_free(iodev); |
goto errout3;
- if (ret) {
- goto errout4;
if (ret) {
- goto errout5;
+ goto errout4;
ret = -EINVAL;
- goto errout6;
+ goto errout5;
if (ret < 0) {
- goto errout6;
+ goto errout5;
ret = -EINVAL;
- goto errout6;
+ goto errout5;
if (ret)
- goto errout6;
+ goto errout5;
return 0;
-errout6:
errout5:
errout4:
clk_put(info->clk);
errout3:
clk_put(info->clk);
