drivers/staging/crystalhd/crystalhd_lnx.c: adjust inconsistent IS_ERR and PTR_ERR
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Change the call to PTR_ERR to access the value just tested by IS_ERR.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
expression e,e1;
if (IS_ERR(e)) { ... PTR_ERR(e) ... }
if (IS_ERR(e=e1)) { ... PTR_ERR(e) ... }
*if (IS_ERR(e))
*  PTR_ERR(e1)
Signed-off-by: Julia Lawall
 drivers/staging/crystalhd/crystalhd_lnx.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/crystalhd/crystalhd_lnx.c b/drivers/staging/crystalhd/crystalhd_lnx.c
index 5909d8d..166203a 100644
--- a/drivers/staging/crystalhd/crystalhd_lnx.c
+++ b/drivers/staging/crystalhd/crystalhd_lnx.c
@@ -381,7 +381,7 @@ static int __devinit chd_dec_init_chdev(struct crystalhd_adp *adp)
 	dev = device_create(crystalhd_class, NULL, MKDEV(adp->chd_dec_major, 0),
 			    NULL, "crystalhd");
 	if (IS_ERR(dev)) {
-		rc = PTR_ERR(crystalhd_class);
+		rc = PTR_ERR(dev);
 		BCMLOG_ERR("failed to create device\n");
 		goto device_create_fail;
BtrLinux
Privacy Overview
