drivers/staging/bcm/nvm.c: add missing kfree
Buff is only used as a temporary buffer within the function, so it should
be freed before leaving the function in an error case.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
@exists@
local idexpression x;
statement S,S1;
expression E;
identifier fl;
expression *ptr != NULL;
x = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
     when != if (...) { <+...kfree(x)...+> }
     when any
     when != true x == NULL
x->fl
if (x == NULL) S1
if (...) { ... when != x
               when forall
 return \(0\|<+...x...+>\|ptr\);
* return ...;
Signed-off-by: Julia Lawall
 drivers/staging/bcm/nvm.c | 13 +++++++++----
 1 file changed, 9 insertions(+), 4 deletions(-)
diff --git a/drivers/staging/bcm/nvm.c b/drivers/staging/bcm/nvm.c
index 4da5b7b..3de0daf 100644
--- a/drivers/staging/bcm/nvm.c
+++ b/drivers/staging/bcm/nvm.c
@@ -4013,7 +4013,8 @@ INT BcmCopyISO(PMINI_ADAPTER Adapter, FLASH2X_COPY_SECTION sCopySectStrut)
 		if(uiTotalDataToCopy < ISOLength)
 			BCM_DEBUG_PRINT(Adapter,DBG_TYPE_PRINTK, 0, 0,"error as Source ISO Section does not have valid signature");
-			return STATUS_FAILURE;
+			Status = STATUS_FAILURE;
+			goto out;
 		uiTotalDataToCopy =(Adapter->psFlash2xCSInfo->OffsetISOImage2Part1End) -
@@ -4026,7 +4027,8 @@ INT BcmCopyISO(PMINI_ADAPTER Adapter, FLASH2X_COPY_SECTION sCopySectStrut)
 			BCM_DEBUG_PRINT(Adapter,DBG_TYPE_PRINTK, 0, 0,"error as Dest ISO Section does not have enough section size");
+			goto out;
 		uiTotalDataToCopy = ISOLength;
@@ -4143,7 +4145,8 @@ INT BcmCopyISO(PMINI_ADAPTER Adapter, FLASH2X_COPY_SECTION sCopySectStrut)
+			goto out;
 		uiTotalDataToCopy =(Adapter->psFlash2xCSInfo->OffsetISOImage1Part1End) -
@@ -4156,7 +4159,8 @@ INT BcmCopyISO(PMINI_ADAPTER Adapter, FLASH2X_COPY_SECTION sCopySectStrut)
+			goto out;
@@ -4257,6 +4261,7 @@ INT BcmCopyISO(PMINI_ADAPTER Adapter, FLASH2X_COPY_SECTION sCopySectStrut)
+out:
 	kfree(Buff);
 	return Status;
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
