drivers/staging: Remove useless return variables
Author: Peter Senna Tschudin <peter.senna@gmail.com>
This patch remove variables that are initialized with a constant,
are never updated, and are only used as parameter of return.
Return the constant instead of using a variable.
Verified by compilation only.
The coccinelle script that find and fixes this issue is:
type T;
constant C;
identifier ret;
- T ret = C;
... when != ret
    when strict
return
- ret
+ C
Signed-off-by: Peter Senna Tschudin
 drivers/staging/bcm/Bcmchar.c                             | 3 +--
 drivers/staging/bcm/InterfaceIdleMode.c                   | 3 +--
 drivers/staging/bcm/PHSModule.c                           | 9 +++------
 drivers/staging/rtl8192e/rtl8192e/r8192E_phy.c            | 3 +--
 drivers/staging/rtl8192e/rtllib_rx.c                      | 3 +--
 drivers/staging/rtl8192e/rtllib_softmac.c                 | 3 +--
 drivers/staging/rtl8192e/rtllib_softmac_wx.c              | 4 +---
 drivers/staging/rtl8192u/ieee80211/ieee80211_rx.c         | 3 +--
 drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c    | 3 +--
 drivers/staging/rtl8192u/ieee80211/ieee80211_softmac_wx.c | 4 +---
 drivers/staging/rtl8192u/ieee80211/rtl819x_HTProc.c       | 3 +--
 drivers/staging/rtl8192u/r819xU_cmdpkt.c                  | 3 +--
 drivers/staging/rtl8192u/r819xU_phy.c                     | 3 +--
 drivers/staging/sep/sep_main.c                            | 3 +--
 drivers/staging/silicom/bpctl_mod.c                       | 4 ++--
 drivers/staging/wlan-ng/hfa384x_usb.c                     | 3 +--
 drivers/staging/wlan-ng/p80211req.c                       | 3 +--
 17 files changed, 20 insertions(+), 40 deletions(-)
diff --git a/drivers/staging/bcm/Bcmchar.c b/drivers/staging/bcm/Bcmchar.c
index 52809dc..606d5f5 100644
--- a/drivers/staging/bcm/Bcmchar.c
+++ b/drivers/staging/bcm/Bcmchar.c
@@ -1849,7 +1849,6 @@ static int bcm_char_ioctl_flash2x_section_bitmap(void __user *argp,
 	struct bcm_flash2x_bitmap *psFlash2xBitMap;
 	struct bcm_ioctl_buffer IoBuffer;
-	INT Status = STATUS_FAILURE;
 BCM_DEBUG_PRINT(Adapter, DBG_TYPE_OTHERS, OSAL_DBG, DBG_LVL_ALL,
 	"IOCTL_BCM_GET_FLASH2X_SECTION_BITMAP Called");
@@ -1892,7 +1891,7 @@ BCM_DEBUG_PRINT(Adapter, DBG_TYPE_OTHERS, OSAL_DBG, DBG_LVL_ALL,
 	kfree(psFlash2xBitMap);
-	return Status;
+	return STATUS_FAILURE;
 static int bcm_char_ioctl_set_active_section(void __user *argp,
diff --git a/drivers/staging/bcm/InterfaceIdleMode.c b/drivers/staging/bcm/InterfaceIdleMode.c
index fecf81f..c84ee49 100644
--- a/drivers/staging/bcm/InterfaceIdleMode.c
+++ b/drivers/staging/bcm/InterfaceIdleMode.c
@@ -223,7 +223,6 @@ static int InterfaceAbortIdlemode(struct bcm_mini_adapter *Adapter,
 int InterfaceIdleModeWakeup(struct bcm_mini_adapter *Adapter)
-	ULONG	Status = 0;
 	if (Adapter->bTriedToWakeUpFromlowPowerMode) {
 		IDLE_MODE, DBG_LVL_ALL,
@@ -233,7 +232,7 @@ int InterfaceIdleModeWakeup(struct bcm_mini_adapter *Adapter)
 		InterfaceAbortIdlemode(Adapter, Adapter->usIdleModePattern);
-	return Status;
+	return 0;
 void InterfaceHandleShutdownModeWakeup(struct bcm_mini_adapter *Adapter)
diff --git a/drivers/staging/bcm/PHSModule.c b/drivers/staging/bcm/PHSModule.c
index afc7bcc..07c5a0b 100644
--- a/drivers/staging/bcm/PHSModule.c
+++ b/drivers/staging/bcm/PHSModule.c
@@ -409,7 +409,6 @@ ULONG PhsUpdateClassifierRule(IN void *pvContext,
 ULONG PhsDeletePHSRule(IN void *pvContext, IN B_UINT16 uiVcid, IN B_UINT8 u8PHSI)
-	ULONG lStatus = 0;
 	UINT nSFIndex = 0, nClsidIndex = 0;
 	struct bcm_phs_entry *pstServiceFlowEntry = NULL;
 	struct bcm_phs_classifier_table *pstClassifierRulesTable = NULL;
@@ -446,7 +445,7 @@ ULONG PhsDeletePHSRule(IN void *pvContext, IN B_UINT16 uiVcid, IN B_UINT8 u8PHSI
-	return lStatus;
+	return 0;
@@ -467,7 +466,6 @@ ULONG PhsDeletePHSRule(IN void *pvContext, IN B_UINT16 uiVcid, IN B_UINT8 u8PHSI
 ULONG PhsDeleteClassifierRule(IN void *pvContext, IN B_UINT16 uiVcid, IN B_UINT16 uiClsId)
 	struct bcm_phs_classifier_entry *pstClassifierEntry = NULL;
@@ -504,7 +502,7 @@ ULONG PhsDeleteClassifierRule(IN void *pvContext, IN B_UINT16 uiVcid, IN B_UINT1
 			memset(pstClassifierEntry, 0, sizeof(struct bcm_phs_classifier_entry));
-	return lStatus;
+	return 0;
@@ -524,7 +522,6 @@ ULONG PhsDeleteClassifierRule(IN void *pvContext, IN B_UINT16 uiVcid, IN B_UINT1
 ULONG PhsDeleteSFRules(IN void *pvContext, IN B_UINT16 uiVcid)
@@ -573,7 +570,7 @@ ULONG PhsDeleteSFRules(IN void *pvContext, IN B_UINT16 uiVcid)
 		pstServiceFlowEntry->uiVcid = 0;
-	return lStatus;
+	return 0;
diff --git a/drivers/staging/rtl8192e/rtl8192e/r8192E_phy.c b/drivers/staging/rtl8192e/rtl8192e/r8192E_phy.c
index b4bfafe..8848921 100644
--- a/drivers/staging/rtl8192e/rtl8192e/r8192E_phy.c
+++ b/drivers/staging/rtl8192e/rtl8192e/r8192E_phy.c
@@ -729,7 +729,6 @@ u8 rtl8192_phy_ConfigRFWithHeaderFile(struct net_device *dev,
 	int i;
-	u8 ret = 0;
 	switch (eRFPath) {
 	case RF90_PATH_A:
@@ -787,7 +786,7 @@ u8 rtl8192_phy_ConfigRFWithHeaderFile(struct net_device *dev,
 		break;
-	return ret;
+	return 0;
 static void rtl8192_SetTxPowerLevel(struct net_device *dev, u8 channel)
diff --git a/drivers/staging/rtl8192e/rtllib_rx.c b/drivers/staging/rtl8192e/rtllib_rx.c
index 7413816..60de54c 100644
--- a/drivers/staging/rtl8192e/rtllib_rx.c
+++ b/drivers/staging/rtl8192e/rtllib_rx.c
@@ -1589,7 +1589,6 @@ static int rtllib_qos_convert_ac_to_parameters(struct rtllib_qos_parameter_info
 	struct rtllib_qos_ac_parameter *ac_params;
 	struct rtllib_qos_parameters *qos_param = &(qos_data->parameters);
-	int rc = 0;
 	int i;
 	u8 aci;
 	u8 acm;
@@ -1640,7 +1639,7 @@ static int rtllib_qos_convert_ac_to_parameters(struct rtllib_qos_parameter_info
 		    (ac_params->aci_aifsn & 0x10) ? 0x01 : 0x00;
 		qos_param->tx_op_limit[aci] = ac_params->tx_op_limit;
-	return rc;
+	return 0;
diff --git a/drivers/staging/rtl8192e/rtllib_softmac.c b/drivers/staging/rtl8192e/rtllib_softmac.c
index d65cba4..684ceed 100644
--- a/drivers/staging/rtl8192e/rtllib_softmac.c
+++ b/drivers/staging/rtl8192e/rtllib_softmac.c
@@ -3239,7 +3239,6 @@ static int rtllib_wpa_set_auth_algs(struct rtllib_device *ieee, int value)
 	struct rtllib_security sec = {
 		.flags = SEC_AUTH_MODE,
-	int ret = 0;
 	if (value & AUTH_ALG_SHARED_KEY) {
 		sec.auth_mode = WLAN_AUTH_SHARED_KEY;
@@ -3259,7 +3258,7 @@ static int rtllib_wpa_set_auth_algs(struct rtllib_device *ieee, int value)
 	if (ieee->set_security)
 		ieee->set_security(ieee->dev, &sec);
-	return ret;
+	return 0;
 static int rtllib_wpa_set_param(struct rtllib_device *ieee, u8 name, u32 value)
diff --git a/drivers/staging/rtl8192e/rtllib_softmac_wx.c b/drivers/staging/rtl8192e/rtllib_softmac_wx.c
index e6af8cf..65b650c 100644
--- a/drivers/staging/rtl8192e/rtllib_softmac_wx.c
+++ b/drivers/staging/rtl8192e/rtllib_softmac_wx.c
@@ -628,8 +628,6 @@ int rtllib_wx_get_power(struct rtllib_device *ieee,
 				 struct iw_request_info *info,
 				 union iwreq_data *wrqu, char *extra)
-	int ret = 0;
 	down(&ieee->wx_sem);
 	if (ieee->ps == RTLLIB_PS_DISABLED) {
@@ -657,7 +655,7 @@ int rtllib_wx_get_power(struct rtllib_device *ieee,
 exit:
 	up(&ieee->wx_sem);
-	return ret;
+	return 0;
 EXPORT_SYMBOL(rtllib_wx_get_power);
diff --git a/drivers/staging/rtl8192u/ieee80211/ieee80211_rx.c b/drivers/staging/rtl8192u/ieee80211/ieee80211_rx.c
index 0cd6a00..d9a8299 100644
--- a/drivers/staging/rtl8192u/ieee80211/ieee80211_rx.c
+++ b/drivers/staging/rtl8192u/ieee80211/ieee80211_rx.c
@@ -1477,7 +1477,6 @@ static int ieee80211_qos_convert_ac_to_parameters(struct
 						  ieee80211_qos_parameters
 						  *qos_param)
-	int rc = 0;
 	int i;
 	struct ieee80211_qos_ac_parameter *ac_params;
 	u8 aci;
@@ -1504,7 +1503,7 @@ static int ieee80211_qos_convert_ac_to_parameters(struct
 		qos_param->tx_op_limit[aci] = le16_to_cpu(ac_params->tx_op_limit);
-	return rc;
+	return 0;
diff --git a/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c b/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c
index 5274ff0..c5a0a5d 100644
--- a/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c
+++ b/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c
@@ -2854,7 +2854,6 @@ static int ieee80211_wpa_set_auth_algs(struct ieee80211_device *ieee, int value)
 	struct ieee80211_security sec = {
-	int ret = 0;
@@ -2877,7 +2876,7 @@ static int ieee80211_wpa_set_auth_algs(struct ieee80211_device *ieee, int value)
 	//else
 	//	ret = -EOPNOTSUPP;
-	return ret;
+	return 0;
 static int ieee80211_wpa_set_param(struct ieee80211_device *ieee, u8 name, u32 value)
diff --git a/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac_wx.c b/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac_wx.c
index a381768..935a8f4 100644
--- a/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac_wx.c
+++ b/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac_wx.c
@@ -570,8 +570,6 @@ int ieee80211_wx_get_power(struct ieee80211_device *ieee,
-	int ret =0;
 	if(ieee->ps == IEEE80211_PS_DISABLED){
@@ -601,7 +599,7 @@ int ieee80211_wx_get_power(struct ieee80211_device *ieee,
 exit:
 	up(&ieee->wx_sem);
-	return ret;
+	return 0;
 EXPORT_SYMBOL(ieee80211_wx_get_power);
diff --git a/drivers/staging/rtl8192u/ieee80211/rtl819x_HTProc.c b/drivers/staging/rtl8192u/ieee80211/rtl819x_HTProc.c
index e7c54ac..2694a08 100644
--- a/drivers/staging/rtl8192u/ieee80211/rtl819x_HTProc.c
+++ b/drivers/staging/rtl8192u/ieee80211/rtl819x_HTProc.c
@@ -415,8 +415,7 @@ static void HTIOTPeerDetermine(struct ieee80211_device *ieee)
 static u8 HTIOTActIsDisableMCS14(struct ieee80211_device *ieee, u8 *PeerMacAddr)
-	u8 ret = 0;
-	return ret;
+	return 0;
diff --git a/drivers/staging/rtl8192u/r819xU_cmdpkt.c b/drivers/staging/rtl8192u/r819xU_cmdpkt.c
index 723c863..545f49e 100644
--- a/drivers/staging/rtl8192u/r819xU_cmdpkt.c
+++ b/drivers/staging/rtl8192u/r819xU_cmdpkt.c
@@ -28,7 +28,6 @@
 rt_status SendTxCommandPacket(struct net_device *dev, void *pData, u32 DataLen)
-	rt_status	rtStatus = RT_STATUS_SUCCESS;
 	struct r8192_priv   *priv = ieee80211_priv(dev);
 	struct sk_buff	    *skb;
 	cb_desc		    *tcb_desc;
@@ -58,7 +57,7 @@ rt_status SendTxCommandPacket(struct net_device *dev, void *pData, u32 DataLen)
 		priv->ieee80211->softmac_hard_start_xmit(skb, dev);
-	return rtStatus;
+	return RT_STATUS_SUCCESS;
diff --git a/drivers/staging/rtl8192u/r819xU_phy.c b/drivers/staging/rtl8192u/r819xU_phy.c
index 87e07ba..02554c9 100644
--- a/drivers/staging/rtl8192u/r819xU_phy.c
+++ b/drivers/staging/rtl8192u/r819xU_phy.c
@@ -991,7 +991,6 @@ u8 rtl8192_phy_ConfigRFWithHeaderFile(struct net_device *dev,
 	int i;
-	u8 ret = 0;
 	switch (eRFPath) {
 	case RF90_PATH_A:
@@ -1058,7 +1057,7 @@ u8 rtl8192_phy_ConfigRFWithHeaderFile(struct net_device *dev,
 		break;
-	return ret;
+	return 0;
diff --git a/drivers/staging/sep/sep_main.c b/drivers/staging/sep/sep_main.c
index e301207..75ca15e 100644
--- a/drivers/staging/sep/sep_main.c
+++ b/drivers/staging/sep/sep_main.c
@@ -1400,7 +1400,6 @@ static int sep_lli_table_secure_dma(struct sep_device *sep,
 	struct sep_dma_context *dma_ctx)
-	int error = 0;
 	u32 count;
 	/* The the page of the end address of the user space buffer */
 	u32 end_page;
@@ -1491,7 +1490,7 @@ static int sep_lli_table_secure_dma(struct sep_device *sep,
 	dma_ctx->dma_res_arr[dma_ctx->nr_dcb_creat].out_map_array = NULL;
 	dma_ctx->dma_res_arr[dma_ctx->nr_dcb_creat].out_map_num_entries = 0;
-	return error;
+	return 0;
diff --git a/drivers/staging/silicom/bpctl_mod.c b/drivers/staging/silicom/bpctl_mod.c
index 22bf4bf..f74b5e7 100644
--- a/drivers/staging/silicom/bpctl_mod.c
+++ b/drivers/staging/silicom/bpctl_mod.c
@@ -1564,7 +1564,7 @@ int pulse_set_fn(struct bpctl_dev *pbpctl_dev, unsigned int counter)
 int zero_set_fn(struct bpctl_dev *pbpctl_dev)
-	uint32_t ctrl_ext = 0, ctrl_value = 0;
+	uint32_t ctrl_ext = 0;
 	if (!pbpctl_dev)
 		return -1;
@@ -1585,7 +1585,7 @@ int zero_set_fn(struct bpctl_dev *pbpctl_dev)
 							   BPCTLI_CTRL_EXT_MDIO_DATA)));
-	return ctrl_value;
+	return 0;
 int pulse_get2_fn(struct bpctl_dev *pbpctl_dev)
diff --git a/drivers/staging/wlan-ng/hfa384x_usb.c b/drivers/staging/wlan-ng/hfa384x_usb.c
index f0ab5a2..98343ff7 100644
--- a/drivers/staging/wlan-ng/hfa384x_usb.c
+++ b/drivers/staging/wlan-ng/hfa384x_usb.c
@@ -2642,7 +2642,6 @@ done:
 int hfa384x_drvr_stop(hfa384x_t *hw)
-	int result = 0;
 	int i;
 	might_sleep();
@@ -2667,7 +2666,7 @@ int hfa384x_drvr_stop(hfa384x_t *hw)
 	for (i = 0; i < HFA384x_NUMPORTS_MAX; i++)
 		hw->port_enabled[i] = 0;
-	return result;
+	return 0;
diff --git a/drivers/staging/wlan-ng/p80211req.c b/drivers/staging/wlan-ng/p80211req.c
index 97795749..7221379 100644
--- a/drivers/staging/wlan-ng/p80211req.c
+++ b/drivers/staging/wlan-ng/p80211req.c
@@ -95,7 +95,6 @@ static void p80211req_mibset_mibget(wlandevice_t *wlandev,
 int p80211req_dorequest(wlandevice_t *wlandev, u8 *msgbuf)
-	int result = 0;
 	struct p80211msg *msg = (struct p80211msg *) msgbuf;
 	/* Check to make sure the MSD is running */
@@ -129,7 +128,7 @@ int p80211req_dorequest(wlandevice_t *wlandev, u8 *msgbuf)
 		wlandev->mlmerequest(wlandev, msg);
 	clear_bit(1, &(wlandev->request_pending));
-	return result;	/* if result==0, msg->status still may contain an err */
+	return 0;	/* if result==0, msg->status still may contain an err */
BtrLinux
Privacy Overview
