drivers/staging: adjust double test
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Rewrite a duplicated test to test the correct value
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
expression E;
* E
|| ... || E
* E
&& ... && E
Signed-off-by: Julia Lawall
drivers/staging/rtl8192e/rtllib_rx.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/rtl8192e/rtllib_rx.c b/drivers/staging/rtl8192e/rtllib_rx.c
index 6c5061f..13979b5 100644
--- a/drivers/staging/rtl8192e/rtllib_rx.c
+++ b/drivers/staging/rtl8192e/rtllib_rx.c
@@ -2453,7 +2453,7 @@ static inline void update_network(struct rtllib_network *dst,
if (src->wmm_param[0].ac_aci_acm_aifsn ||
src->wmm_param[1].ac_aci_acm_aifsn ||
src->wmm_param[2].ac_aci_acm_aifsn ||
- src->wmm_param[1].ac_aci_acm_aifsn)
+ src->wmm_param[3].ac_aci_acm_aifsn)
memcpy(dst->wmm_param, src->wmm_param, WME_AC_PRAM_LEN);
dst->SignalStrength = src->SignalStrength; |
