drivers/serial/uartlite.c: Add missing of_node_put
There should be an of_node_put when breaking out of a loop that iterates
using for_each_compatible_node.
This was detected and fixed using the following semantic patch.
(http://www.emn.fr/x-info/coccinelle/)
identifier d;
type T;
expression e;
iterator for_each_compatible_node;
T *d;
for_each_compatible_node(d,...)
  {... when != of_node_put(d)
       when != e = d
   return d;
+  of_node_put(d);
?  return ...;
Signed-off-by: Julia Lawall
Acked-by: Grant Likely
Acked-by: Peter Korsgaard
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 drivers/serial/uartlite.c | 1 +
 1 file changed, 1 insertion(+)
diff --git a/drivers/serial/uartlite.c b/drivers/serial/uartlite.c
index a85f2d3..3f59324 100644
--- a/drivers/serial/uartlite.c
+++ b/drivers/serial/uartlite.c
@@ -393,6 +393,7 @@ static inline void __init ulite_console_of_find_device(int id)
 			continue;
 		ulite_ports[id].mapbase = res.start;
+		of_node_put(np);
 		return;
 			continue;
+		of_node_put(np);
 		return;
