drivers/scsi/aic94xx/aic94xx_init.c: correct the size argument to kmalloc
In each case, the destination of the allocation has type struct **, so the
elements of the array should have pointer type, not structure type.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
@disable sizeof_type_expr@
type T;
T **x;
  x =
  <+...sizeof(
- T
+ *x
Signed-off-by: Julia Lawall
Cc: Rolf Eike Beer
Cc: Joe Perches
Cc: James Bottomley
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 drivers/scsi/aic94xx/aic94xx_init.c | 4 ++--
 drivers/scsi/ch.c                   | 2 +-
 2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/scsi/aic94xx/aic94xx_init.c b/drivers/scsi/aic94xx/aic94xx_init.c
index 24ac231..3b7e83d 100644
--- a/drivers/scsi/aic94xx/aic94xx_init.c
+++ b/drivers/scsi/aic94xx/aic94xx_init.c
@@ -688,9 +688,9 @@ static int asd_register_sas_ha(struct asd_ha_struct *asd_ha)
 	int i;
 	struct asd_sas_phy   **sas_phys =
-		kmalloc(ASD_MAX_PHYS * sizeof(struct asd_sas_phy), GFP_KERNEL);
+		kcalloc(ASD_MAX_PHYS, sizeof(*sas_phys), GFP_KERNEL);
 	struct asd_sas_port  **sas_ports =
-		kmalloc(ASD_MAX_PHYS * sizeof(struct asd_sas_port), GFP_KERNEL);
+		kcalloc(ASD_MAX_PHYS, sizeof(*sas_ports), GFP_KERNEL);
 	if (!sas_phys || !sas_ports) {
 		kfree(sas_phys);
diff --git a/drivers/scsi/ch.c b/drivers/scsi/ch.c
index 4799d43..769b35f 100644
--- a/drivers/scsi/ch.c
+++ b/drivers/scsi/ch.c
@@ -352,7 +352,7 @@ ch_readconfig(scsi_changer *ch)
 	/* look up the devices of the data transfer elements */
-	ch->dt = kmalloc(ch->counts[CHET_DT]*sizeof(struct scsi_device),
+	ch->dt = kcalloc(ch->counts[CHET_DT], sizeof(*ch->dt),
 			 GFP_KERNEL);
 	if (!ch->dt) {
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
