drivers/scsi: use memdup_user
Use memdup_user when user data is immediately copied into the
allocated region.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
expression from,to,size,flag;
position p;
identifier l1,l2;
-  to = \(kmalloc@p\|kzalloc@p\)(size,flag);
+  to = memdup_user(from,size);
   if (
-      to==NULL
+      IS_ERR(to)
   <+... when != goto l1;
-  -ENOMEM
+  PTR_ERR(to)
-  if (copy_from_user(to, from, size) != 0) {
-    <+... when != goto l2;
-    -EFAULT
Signed-off-by: Julia Lawall
Cc: Doug Gilbert
Cc: Boaz Harrosh
Cc: James Bottomley
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 drivers/scsi/sg.c | 11 +++--------
 1 file changed, 3 insertions(+), 8 deletions(-)
diff --git a/drivers/scsi/sg.c b/drivers/scsi/sg.c
index 2968c6b..78d6163 100644
--- a/drivers/scsi/sg.c
+++ b/drivers/scsi/sg.c
@@ -1686,14 +1686,9 @@ static int sg_start_req(Sg_request *srp, unsigned char *cmd)
 		int len, size = sizeof(struct sg_iovec) * iov_count;
 		struct iovec *iov;
-		iov = kmalloc(size, GFP_ATOMIC);
-		if (!iov)
-			return -ENOMEM;
-		if (copy_from_user(iov, hp->dxferp, size)) {
-			kfree(iov);
-			return -EFAULT;
+		iov = memdup_user(hp->dxferp, size);
+		if (IS_ERR(iov))
+			return PTR_ERR(iov);
 		len = iov_length(iov, iov_count);
 		if (hp->dxfer_len < len) {
BtrLinux
Privacy Overview
