drivers/s390/char/monreader.c: fix error return code
Author: Peter Senna Tschudin <peter.senna@gmail.com>
Convert a nonnegative error return code to a negative one, as returned
elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
if@p1 (\(ret < 0\|ret != 0\))
{ ... return ret; }
ret@p1 = 0
... when != ret = e1
when != &ret
*if(...)
... when != ret = e2
when forall
return ret;
Signed-off-by: Peter Senna Tschudin
Signed-off-by: Gerald Schaefer
Signed-off-by: Martin Schwidefsky
drivers/s390/char/monreader.c | 5 ++++-
1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/drivers/s390/char/monreader.c b/drivers/s390/char/monreader.c
index 5b8b859..f4ff515 100644
--- a/drivers/s390/char/monreader.c
+++ b/drivers/s390/char/monreader.c
@@ -571,8 +571,11 @@ static int __init mon_init(void)
if (rc)
goto out_iucv;
monreader_device = kzalloc(sizeof(struct device), GFP_KERNEL);
- if (!monreader_device)
+ if (!monreader_device) {
+ rc = -ENOMEM;
goto out_driver;
dev_set_name(monreader_device, "monreader-dev");
monreader_device->bus = &iucv_bus;
monreader_device->parent = iucv_root; |
if (rc)
goto out_iucv;
+ rc = -ENOMEM;
goto out_driver;
