drivers/rtc/rtc-coh901331.c: use clk_prepare_enable() and clk_disable_unprepare()
Author: Julia Lawall <Julia.Lawall@lip6.fr>
clk_prepare_enable and clk_disable_unprepare combine clk_prepare and
clk_enable, and clk_disable and clk_unprepare.  They make the code more
concise, and ensure that clk_unprepare is called when clk_enable fails.
A simplified version of the semantic patch that introduces calls to these
functions is as follows: (http://coccinelle.lip6.fr/)
expression e;
- clk_prepare(e);
- clk_enable(e);
+ clk_prepare_enable(e);
expression e;
- clk_disable(e);
- clk_unprepare(e);
+ clk_disable_unprepare(e);
Signed-off-by: Julia Lawall
Acked-by: Linus Walleij
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 drivers/rtc/rtc-coh901331.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/rtc/rtc-coh901331.c b/drivers/rtc/rtc-coh901331.c
index 76b2156..c8115b8 100644
--- a/drivers/rtc/rtc-coh901331.c
+++ b/drivers/rtc/rtc-coh901331.c
@@ -276,8 +276,7 @@ static void coh901331_shutdown(struct platform_device *pdev)
 	clk_enable(rtap->clk);
 	writel(0, rtap->virtbase + COH901331_IRQ_MASK);
-	clk_disable(rtap->clk);
-	clk_unprepare(rtap->clk);
+	clk_disable_unprepare(rtap->clk);
 static struct platform_driver coh901331_driver = {
BtrLinux
Privacy Overview
