drivers/rtc/: remove redundant spi driver bus initialization
Author: Lars-Peter Clausen <lars@metafoo.de>
In ancient times it was necessary to manually initialize the bus field of
an spi_driver to spi_bus_type.  These days this is done in
spi_driver_register(), so we can drop the manual assignment.
The patch was generated using the following coccinelle semantic patch:
identifier _driver;
struct spi_driver _driver = {
	.driver = {
-		.bus = &spi_bus_type,
Signed-off-by: Lars-Peter Clausen
Cc: John Stultz
Cc: Alessandro Zummo
Cc: Grant Likely
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 drivers/rtc/rtc-m41t93.c  | 1 -
 drivers/rtc/rtc-m41t94.c  | 1 -
 drivers/rtc/rtc-max6902.c | 1 -
 drivers/rtc/rtc-pcf2123.c | 1 -
 drivers/rtc/rtc-rs5c348.c | 1 -
 5 files changed, 5 deletions(-)
diff --git a/drivers/rtc/rtc-m41t93.c b/drivers/rtc/rtc-m41t93.c
index 7317d3b..ef71132 100644
--- a/drivers/rtc/rtc-m41t93.c
+++ b/drivers/rtc/rtc-m41t93.c
@@ -200,7 +200,6 @@ static int __devexit m41t93_remove(struct spi_device *spi)
 static struct spi_driver m41t93_driver = {
 	.driver = {
 		.name	= "rtc-m41t93",
 		.owner	= THIS_MODULE,
 	.probe	= m41t93_probe,
diff --git a/drivers/rtc/rtc-m41t94.c b/drivers/rtc/rtc-m41t94.c
index e259ed7..2a4721f 100644
--- a/drivers/rtc/rtc-m41t94.c
+++ b/drivers/rtc/rtc-m41t94.c
@@ -147,7 +147,6 @@ static int __devexit m41t94_remove(struct spi_device *spi)
 static struct spi_driver m41t94_driver = {
 	.driver = {
 		.name	= "rtc-m41t94",
 	.probe	= m41t94_probe,
diff --git a/drivers/rtc/rtc-max6902.c b/drivers/rtc/rtc-max6902.c
index 0ec3f588..1f6b3cc 100644
--- a/drivers/rtc/rtc-max6902.c
+++ b/drivers/rtc/rtc-max6902.c
@@ -154,7 +154,6 @@ static int __devexit max6902_remove(struct spi_device *spi)
 static struct spi_driver max6902_driver = {
 	.driver = {
 		.name	= "rtc-max6902",
 	.probe	= max6902_probe,
diff --git a/drivers/rtc/rtc-pcf2123.c b/drivers/rtc/rtc-pcf2123.c
index 2ee3bbf..b46c400 100644
--- a/drivers/rtc/rtc-pcf2123.c
+++ b/drivers/rtc/rtc-pcf2123.c
@@ -340,7 +340,6 @@ static int __devexit pcf2123_remove(struct spi_device *spi)
 static struct spi_driver pcf2123_driver = {
 	.driver	= {
 			.name	= "rtc-pcf2123",
 	.probe	= pcf2123_probe,
diff --git a/drivers/rtc/rtc-rs5c348.c b/drivers/rtc/rtc-rs5c348.c
index 971bc8e..ce2ca85 100644
--- a/drivers/rtc/rtc-rs5c348.c
+++ b/drivers/rtc/rtc-rs5c348.c
@@ -229,7 +229,6 @@ static int __devexit rs5c348_remove(struct spi_device *spi)
 static struct spi_driver rs5c348_driver = {
 	.driver = {
 		.name	= "rtc-rs5c348",
 	.probe	= rs5c348_probe,
BtrLinux
Privacy Overview
