drivers/rtc: correct an error test
rtc is clearly does not satisfy IS_ERR at the point where it is tested, so
I have changed the test to consider the just initialized rtc->rtc_dev.
The semantic match that finds the problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@match exists@
expression x, E;
identifier fld;
position p1,p2;
x = E;
x = E
x@p1->fld
... when != x = E
IS_ERR(x@p2)
... when any
@other_match exists@
expression match.x, E1, E2;
position match.p1,match.p2;
x = E1
... when != x = E2
    when != x@p1
x@p2
@ script:python depends on !other_match@
p1 << match.p1;
p2 << match.p2;
print "* file %s dereference %s test %s" % (p1[0].file,p1[0].line,p2[0].line)
Signed-off-by: Julia Lawall
Acked-by: Alessandro Zummo
Cc: David Brownell
Cc: Bryan Wu
Cc: Mike Frysinger
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 drivers/rtc/rtc-bfin.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/rtc/rtc-bfin.c b/drivers/rtc/rtc-bfin.c
index 34439ce..aafd3e6 100644
--- a/drivers/rtc/rtc-bfin.c
+++ b/drivers/rtc/rtc-bfin.c
@@ -390,7 +390,7 @@ static int __devinit bfin_rtc_probe(struct platform_device *pdev)
 	/* Register our RTC with the RTC framework */
 	rtc->rtc_dev = rtc_device_register(pdev->name, dev, &bfin_rtc_ops, THIS_MODULE);
-	if (unlikely(IS_ERR(rtc))) {
+	if (unlikely(IS_ERR(rtc->rtc_dev))) {
 		ret = PTR_ERR(rtc->rtc_dev);
 		goto err_irq;
BtrLinux
Privacy Overview
