drivers/regulator: use PTR_ERR to get error code
IS_ERR returns only 1 or 0. The callsite of setup_regulators expects a
negative integer in an error case. Thus, PTR_ERR has to be used to extract
it.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
expression E,E1;
*E = IS_ERR(...)
... when != E = E1
*return E;
Signed-off-by: Julia Lawall
Acked-by:
Signed-off-by: Liam Girdwood
drivers/regulator/lp3971.c | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/regulator/lp3971.c b/drivers/regulator/lp3971.c
index 7803a32..76d08c2 100644
--- a/drivers/regulator/lp3971.c
+++ b/drivers/regulator/lp3971.c
@@ -446,8 +446,8 @@ static int setup_regulators(struct lp3971 *lp3971,
lp3971->rdev[i] = regulator_register(®ulators[id],
lp3971->dev, pdata->regulators[i].initdata, lp3971);
- err = IS_ERR(lp3971->rdev[i]);
- if (err) {
+ if (IS_ERR(lp3971->rdev[i])) {
+ err = PTR_ERR(lp3971->rdev[i]);
dev_err(lp3971->dev, "regulator init failed: %d\n",
err);
goto error; |
- if (err) {
err);
goto error;
