drivers/regulator: fix when type is different from REGULATOR_VOLTAGE or REGULATOR_CURRENT
Author: Diego Liziero <diegoliz@gmail.com>
When regulator_desc->type is something different from REGULATOR_VOLTAGE or REGULATOR_CURRENT
the if should probably return ERR_PTR(-EINVAL)
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@@ expression E; constant C; @@
- !E == C
+ E != C
Signed-off-by: Diego Liziero
Acked-by: Mark Brown
Signed-off-by: Liam Girdwood
drivers/regulator/core.c | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/regulator/core.c b/drivers/regulator/core.c
index 47fc6e6..cb62be6 100644
--- a/drivers/regulator/core.c
+++ b/drivers/regulator/core.c
@@ -2001,8 +2001,8 @@ struct regulator_dev *regulator_register(struct regulator_desc *regulator_desc,
if (regulator_desc->name == NULL || regulator_desc->ops == NULL)
return ERR_PTR(-EINVAL);
- if (!regulator_desc->type == REGULATOR_VOLTAGE &&
- !regulator_desc->type == REGULATOR_CURRENT)
+ if (regulator_desc->type != REGULATOR_VOLTAGE &&
+ regulator_desc->type != REGULATOR_CURRENT)
if (!init_data) |
if (!init_data)
