drivers/rapidio/devices/tsi721.c: fix error return code
Author: Peter Senna Tschudin <peter.senna@gmail.com>
Convert a nonnegative error return code to a negative one, as returned
elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
if@p1 (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret@p1 = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Peter Senna Tschudin
Acked-by: Alexandre Bounine
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 drivers/rapidio/devices/tsi721.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/rapidio/devices/tsi721.c b/drivers/rapidio/devices/tsi721.c
index 1974359..78dff6f 100644
--- a/drivers/rapidio/devices/tsi721.c
+++ b/drivers/rapidio/devices/tsi721.c
@@ -2316,7 +2316,8 @@ static int __devinit tsi721_probe(struct pci_dev *pdev,
 	/* Configure DMA attributes. */
 	if (pci_set_dma_mask(pdev, DMA_BIT_MASK(64))) {
-		if (pci_set_dma_mask(pdev, DMA_BIT_MASK(32))) {
+		err = pci_set_dma_mask(pdev, DMA_BIT_MASK(32));
+		if (err) {
 			dev_info(&pdev->dev, "Unable to set DMA mask\n");
 			goto err_unmap_bars;
BtrLinux
Privacy Overview
