drivers/platform/x86: Adjust confusing if indentation
The assignment of ret to -EIO appears to only make sense if the branch that
it is aligned with is executed, so move it into that branch.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@r disable braces4@
position p1,p2;
statement S1,S2;
if (...) { ... }
if (...) S1@p1 S2@p2
@script:python@
p1 << r.p1;
p2 << r.p2;
if (p1[0].column == p2[0].column):
cocci.print_main("branch",p1)
cocci.print_secs("after",p2)
Signed-off-by: Julia Lawall
Signed-off-by: Matthew Garrett
drivers/platform/x86/asus_acpi.c | 6 ++++--
1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/drivers/platform/x86/asus_acpi.c b/drivers/platform/x86/asus_acpi.c
index e058c2b..ca05aef 100644
--- a/drivers/platform/x86/asus_acpi.c
+++ b/drivers/platform/x86/asus_acpi.c
@@ -938,10 +938,11 @@ static int set_brightness(int value)
/* SPLV laptop */
if (hotk->methods->brightness_set) {
if (!write_acpi_int(hotk->handle, hotk->methods->brightness_set,
- value, NULL))
+ value, NULL)) {
printk(KERN_WARNING
"Asus ACPI: Error changing brightness\n");
ret = -EIO;
goto out;
@@ -953,10 +954,11 @@ static int set_brightness(int value)
hotk->methods->brightness_down,
NULL, NULL);
(value > 0) ? value-- : value++;
- if (ACPI_FAILURE(status))
+ if (ACPI_FAILURE(status)) {
printk(KERN_WARNING
ret = -EIO;
out:
return ret; |
/* SPLV laptop */
- value, NULL))
+ value, NULL)) {
printk(KERN_WARNING
ret = -EIO;
goto out;
NULL, NULL);
printk(KERN_WARNING
ret = -EIO;
out:
return ret;
