drivers/pcmcia: remove unnecessary kzalloc
The result of calling kzalloc is never used or freed.
The semantic match that finds this problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@r exists@
local idexpression x;
statement S;
expression E;
identifier f,f1,l;
position p1,p2;
expression *ptr != NULL;
x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
     when != if (...) { <+...x...+> }
x->f1 = E
 (x->f1 == NULL || ...)
 f(...,x->f1,...)
 return \(0\|<+...x...+>\|ptr\);
 return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
Signed-off-by: Julia Lawall
Signed-off-by: Dominik Brodowski
 drivers/pcmcia/sa1111_generic.c | 4 ----
 1 file changed, 4 deletions(-)
diff --git a/drivers/pcmcia/sa1111_generic.c b/drivers/pcmcia/sa1111_generic.c
index deb5036..de6bc33 100644
--- a/drivers/pcmcia/sa1111_generic.c
+++ b/drivers/pcmcia/sa1111_generic.c
@@ -127,10 +127,6 @@ int sa1111_pcmcia_add(struct sa1111_dev *dev, struct pcmcia_low_level *ops,
 	ops->socket_state = sa1111_pcmcia_socket_state;
 	ops->socket_suspend = sa1111_pcmcia_socket_suspend;
-	s = kzalloc(sizeof(*s) * ops->nr, GFP_KERNEL);
-	if (!s)
-		return -ENODEV;
 	for (i = 0; i < ops->nr; i++) {
 		s = kzalloc(sizeof(*s), GFP_KERNEL);
 		if (!s)
BtrLinux
Privacy Overview
