drivers/pcmcia: Add missing iounmap
of_iomap calls ioremap, and so should be matched with an iounmap.  At the
two error returns, the result of calling of_iomap is only stored in a local
variable, so these error paths need to call iounmap.  Furthermore, this
function ultimately stores the result of of_iomap in an array that is local
to the file.  These values should be iounmapped at some point.  I have
added a corresponding call to iounmap at the end of the function
m8xx_remove.
The problem was found using the following semantic match.
(http://www.emn.fr/x-info/coccinelle/)
type T,T1,T2;
identifier E;
statement S;
expression x1,x2,x3;
int ret;
  T E;
* E = of_iomap(...);
  if (E == NULL) S
  ... when != iounmap(...,(T1)E,...)
      when != if (E != NULL) { ... iounmap(...,(T1)E,...); ...}
      when != x1 = (T1)E
      when != E = x3;
      when any
  if (...) {
    ... when != iounmap(...,(T2)E,...)
        when != if (E != NULL) { ... iounmap(...,(T2)E,...); ...}
        when != x2 = (T2)E
*   return;
*   return ret;
Signed-off-by: Julia Lawall
Vitaly Bordug
Cc: Arnd Bergmann
Cc: Olof Johansson
Cc: Dominik Brodowski
Cc: Paul Mackerras
Cc: Benjamin Herrenschmidt
Cc: Kumar Gala
Cc: Stephen Rothwell
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 drivers/pcmcia/m8xx_pcmcia.c | 6 +++++-
 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/drivers/pcmcia/m8xx_pcmcia.c b/drivers/pcmcia/m8xx_pcmcia.c
index 4ea426a..ac70d2c 100644
--- a/drivers/pcmcia/m8xx_pcmcia.c
+++ b/drivers/pcmcia/m8xx_pcmcia.c
@@ -1174,8 +1174,10 @@ static int __init m8xx_probe(struct of_device *ofdev,
 	pcmcia_schlvl = irq_of_parse_and_map(np, 0);
 	hwirq = irq_map[pcmcia_schlvl].hwirq;
-	if (pcmcia_schlvl < 0)
+	if (pcmcia_schlvl < 0) {
+		iounmap(pcmcia);
 		return -EINVAL;
 	m8xx_pgcrx[0] = &pcmcia->pcmc_pgcra;
 	m8xx_pgcrx[1] = &pcmcia->pcmc_pgcrb;
@@ -1189,6 +1191,7 @@ static int __init m8xx_probe(struct of_device *ofdev,
 			driver_name, socket)) {
 		pcmcia_error("Cannot allocate IRQ %u for SCHLVL!\n",
 			     pcmcia_schlvl);
+		iounmap(pcmcia);
 		return -1;
@@ -1284,6 +1287,7 @@ static int m8xx_remove(struct of_device *ofdev)
 	for (i = 0; i < PCMCIA_SOCKETS_NO; i++)
 		pcmcia_unregister_socket(&socket[i].socket);
+	iounmap(pcmcia);
 	free_irq(pcmcia_schlvl, NULL);
