drivers/pci/hotplug: Add missing pci_dev_get
pci_get_slot does a pci_dev_get, so pci_dev_put needs to be called in an
error case.
An alterative would be to move the test_and_set_bit before the call to
pci_get_slot.
The problem was fixed using the following semantic patch.
(http://www.emn.fr/x-info/coccinelle/)
local idexpression *n;
statement S1,S2;
expression E,E1;
expression *ptr != NULL;
type T,T1;
if (!(n = pci_get_slot(...))) S1
<... when != pci_dev_put(n)
    when != if (...) { <+... pci_dev_put(n) ...+> }
    when != true !n  || ...
    when != n = (T)E
    when != E = n
if (!n || ...) S2
  return \(0\|<+...n...+>\|ptr\);
+ pci_dev_put(n);
return ...;
pci_dev_put(n);
n = (T1)E1
E1 = n
Signed-off-by: Julia Lawall
Signed-off-by: Jesse Barnes
 drivers/pci/hotplug/fakephp.c | 1 +
 1 file changed, 1 insertion(+)
diff --git a/drivers/pci/hotplug/fakephp.c b/drivers/pci/hotplug/fakephp.c
index 3a2637a..b0e7de9 100644
--- a/drivers/pci/hotplug/fakephp.c
+++ b/drivers/pci/hotplug/fakephp.c
@@ -324,6 +324,7 @@ static int disable_slot(struct hotplug_slot *slot)
 		if (test_and_set_bit(0, &dslot->removed)) {
 			dbg("Slot already scheduled for removal\n");
+			pci_dev_put(dev);
 			return -ENODEV;
+			pci_dev_put(dev);
 			return -ENODEV;
