drivers/net/wireless/wl12xx: add missing kfree
In each case, the freed data should be freed in the error handling code
as
well.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
@exists@
local idexpression x;
statement S,S1;
expression E;
identifier fl;
expression *ptr != NULL;
x = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
     when != if (...) { <+...kfree(x)...+> }
     when any
     when != true x == NULL
x->fl
if (x == NULL) S1
if (...) { ... when != x
               when forall
 return \(0\|<+...x...+>\|ptr\);
* return ...;
Signed-off-by: Julia Lawall
Acked-by: Luciano Coelho
Signed-off-by: John W. Linville
 drivers/net/wireless/wl12xx/acx.c      | 6 +-----
 drivers/net/wireless/wl12xx/testmode.c | 5 ++++-
 2 files changed, 5 insertions(+), 6 deletions(-)
diff --git a/drivers/net/wireless/wl12xx/acx.c b/drivers/net/wireless/wl12xx/acx.c
index 7e33f1f..34f6ab5 100644
--- a/drivers/net/wireless/wl12xx/acx.c
+++ b/drivers/net/wireless/wl12xx/acx.c
@@ -77,8 +77,6 @@ int wl1271_acx_sleep_auth(struct wl1271 *wl, u8 sleep_auth)
 	auth->sleep_auth = sleep_auth;
 	ret = wl1271_cmd_configure(wl, ACX_SLEEP_AUTH, auth, sizeof(*auth));
-	if (ret < 0)
-		return ret;
 out:
 	kfree(auth);
@@ -624,10 +622,8 @@ int wl1271_acx_cca_threshold(struct wl1271 *wl)
 	ret = wl1271_cmd_configure(wl, ACX_CCA_THRESHOLD,
 				   detection, sizeof(*detection));
-	if (ret < 0) {
+	if (ret < 0)
 		wl1271_warning("failed to set cca threshold: %d", ret);
-		return ret;
 out:
 	kfree(detection);
diff --git a/drivers/net/wireless/wl12xx/testmode.c b/drivers/net/wireless/wl12xx/testmode.c
index 5d5e1ef..88add68 100644
--- a/drivers/net/wireless/wl12xx/testmode.c
+++ b/drivers/net/wireless/wl12xx/testmode.c
@@ -139,12 +139,15 @@ static int wl1271_tm_cmd_interrogate(struct wl1271 *wl, struct nlattr *tb[])
 	if (ret < 0) {
 		wl1271_warning("testmode cmd interrogate failed: %d", ret);
+		kfree(cmd);
 		return ret;
 	skb = cfg80211_testmode_alloc_reply_skb(wl->hw->wiphy, sizeof(*cmd));
-	if (!skb)
+	if (!skb) {
+		kfree(cmd);
 		return -ENOMEM;
 	NLA_PUT(skb, WL1271_TM_ATTR_DATA, sizeof(*cmd), cmd);
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
