drivers/net/wireless/libertas: Use kmemdup
Use kmemdup when some other buffer is immediately copied into the
allocated region.
A simplified version of the semantic patch that makes this change is as
follows: (http://coccinelle.lip6.fr/)
expression from,to,size,flag;
statement S;
-  to = \(kmalloc\|kzalloc\)(size,flag);
+  to = kmemdup(from,size,flag);
   if (to==NULL || ...) S
-  memcpy(to, from, size);
Signed-off-by: Julia Lawall
Acked-by: Dan Williams
Signed-off-by: John W. Linville
 drivers/net/wireless/libertas/if_usb.c | 6 ++----
 1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/drivers/net/wireless/libertas/if_usb.c b/drivers/net/wireless/libertas/if_usb.c
index a0cb265..3678e53 100644
--- a/drivers/net/wireless/libertas/if_usb.c
+++ b/drivers/net/wireless/libertas/if_usb.c
@@ -613,16 +613,14 @@ static void if_usb_receive_fwload(struct urb *urb)
 		return;
-	syncfwheader = kmalloc(sizeof(struct fwsyncheader), GFP_ATOMIC);
+	syncfwheader = kmemdup(skb->data + IPFIELD_ALIGN_OFFSET,
+			       sizeof(struct fwsyncheader), GFP_ATOMIC);
 	if (!syncfwheader) {
 		lbs_deb_usbd(&cardp->udev->dev, "Failure to allocate syncfwheader\n");
 		kfree_skb(skb);
 		return;
-	memcpy(syncfwheader, skb->data + IPFIELD_ALIGN_OFFSET,
-	       sizeof(struct fwsyncheader));
 	if (!syncfwheader->cmd) {
 		lbs_deb_usb2(&cardp->udev->dev, "FW received Blk with correct CRC\n");
 		lbs_deb_usb2(&cardp->udev->dev, "FW received Blk seqnum = %d\n",
BtrLinux
Privacy Overview
