drivers/net/wireless/ipw2x00/ipw2100.c: introduce missing initialization
Author: Julia Lawall <Julia.Lawall@lip6.fr>
The result of one call to a function is tested, and then at the second call
to the same function, the previous result, and not the current result, is
tested again.
Also changed &bssid to bssid, at the suggestion of Stanislav Yakovlev.
The semantic match that finds the first problem is as follows:
(http://coccinelle.lip6.fr/)
expression ret;
identifier f;
statement S1,S2;
*ret = f(...);
if (\(ret != 0\|ret < 0\|ret == NULL\)) S1
... when any
*f(...);
if (\(ret != 0\|ret < 0\|ret == NULL\)) S2
Signed-off-by: Julia Lawall
Signed-off-by: John W. Linville
 drivers/net/wireless/ipw2x00/ipw2100.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/net/wireless/ipw2x00/ipw2100.c b/drivers/net/wireless/ipw2x00/ipw2100.c
index 95aa8e1..83324b3 100644
--- a/drivers/net/wireless/ipw2x00/ipw2100.c
+++ b/drivers/net/wireless/ipw2x00/ipw2100.c
@@ -2042,7 +2042,8 @@ static void isr_indicate_associated(struct ipw2100_priv *priv, u32 status)
 		return;
 	len = ETH_ALEN;
-	ipw2100_get_ordinal(priv, IPW_ORD_STAT_ASSN_AP_BSSID, &bssid, &len);
+	ret = ipw2100_get_ordinal(priv, IPW_ORD_STAT_ASSN_AP_BSSID, bssid,
+				  &len);
 	if (ret) {
 		IPW_DEBUG_INFO("failed querying ordinals at line %d\n",
 			       __LINE__);
BtrLinux
Privacy Overview
