drivers/net/wireless/ipw2100.c: Release mutex in error handling code
The mutex is released on a successful return, so it would seem that it
should be released on an error return as well.
The semantic patch finds this problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
expression l;
mutex_lock(l);
... when != mutex_unlock(l)
    when any
    when strict
if (...) { ... when != mutex_unlock(l)
+   mutex_unlock(l);
    return ...;
mutex_unlock(l);
Signed-off-by: Julia Lawall
Signed-off-by: John W. Linville
 drivers/net/wireless/ipw2100.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/net/wireless/ipw2100.c b/drivers/net/wireless/ipw2100.c
index 5bf9e00..c6f886e 100644
--- a/drivers/net/wireless/ipw2100.c
+++ b/drivers/net/wireless/ipw2100.c
@@ -6442,6 +6442,7 @@ static int ipw2100_resume(struct pci_dev *pci_dev)
 	if (err) {
 		printk(KERN_ERR "%s: pci_enable_device failed on resume\n",
 		       dev->name);
+		mutex_unlock(&priv->action_mutex);
 		return err;
 	pci_restore_state(pci_dev);
@@ -7146,7 +7147,7 @@ static int ipw2100_wx_get_rate(struct net_device *dev,
 	err = ipw2100_get_ordinal(priv, IPW_ORD_CURRENT_TX_RATE, &val, &len);
 	if (err) {
 		IPW_DEBUG_WX("failed querying ordinals.\n");
-		return err;
+		goto done;
 	switch (val & TX_RATE_MASK) {
BtrLinux
Privacy Overview
