drivers/net/wireless/b43: Use kmemdup
Use kmemdup when some other buffer is immediately copied into the
allocated region.
A simplified version of the semantic patch that makes this change is as
follows: (http://coccinelle.lip6.fr/)
expression from,to,size,flag;
statement S;
-  to = \(kmalloc\|kzalloc\)(size,flag);
+  to = kmemdup(from,size,flag);
   if (to==NULL || ...) S
-  memcpy(to, from, size);
Signed-off-by: Julia Lawall
Signed-off-by: John W. Linville
 drivers/net/wireless/b43/dma.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/net/wireless/b43/dma.c b/drivers/net/wireless/b43/dma.c
index fa40fdf..fdfeab0 100644
--- a/drivers/net/wireless/b43/dma.c
+++ b/drivers/net/wireless/b43/dma.c
@@ -1221,14 +1221,14 @@ static int dma_tx_fragment(struct b43_dmaring *ring,
 	meta->dmaaddr = map_descbuffer(ring, skb->data, skb->len, 1);
 	/* create a bounce buffer in zone_dma on mapping failure. */
 	if (b43_dma_mapping_error(ring, meta->dmaaddr, skb->len, 1)) {
-		priv_info->bouncebuffer = kmalloc(skb->len, GFP_ATOMIC | GFP_DMA);
+		priv_info->bouncebuffer = kmemdup(skb->data, skb->len,
+						  GFP_ATOMIC | GFP_DMA);
 		if (!priv_info->bouncebuffer) {
 			ring->current_slot = old_top_slot;
 			ring->used_slots = old_used_slots;
 			err = -ENOMEM;
 			goto out_unmap_hdr;
-		memcpy(priv_info->bouncebuffer, skb->data, skb->len);
 		meta->dmaaddr = map_descbuffer(ring, priv_info->bouncebuffer, skb->len, 1);
BtrLinux
Privacy Overview
