drivers/net/wireless: Use usb_endpoint_dir_out
Use the usb_endpoint_dir_out API function.  Note that the use of
USB_TYPE_MASK in the original code is incorrect; it results in a test that
is always false.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
struct usb_endpoint_descriptor *endpoint;
expression E;
- (endpoint->bEndpointAddress & E) == USB_DIR_OUT
+ usb_endpoint_dir_out(endpoint)
Signed-off-by: Julia Lawall
Signed-off-by: John W. Linville
 drivers/net/wireless/zd1211rw/zd_usb.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/wireless/zd1211rw/zd_usb.c b/drivers/net/wireless/zd1211rw/zd_usb.c
index 3868884..23a6a6d 100644
--- a/drivers/net/wireless/zd1211rw/zd_usb.c
+++ b/drivers/net/wireless/zd1211rw/zd_usb.c
@@ -1070,7 +1070,7 @@ static int eject_installer(struct usb_interface *intf)
 	/* Find bulk out endpoint */
 	endpoint = &iface_desc->endpoint[1].desc;
-	if ((endpoint->bEndpointAddress & USB_TYPE_MASK) == USB_DIR_OUT &&
+	if (usb_endpoint_dir_out(endpoint) &&
 	    usb_endpoint_xfer_bulk(endpoint)) {
 		bulk_out_ep = endpoint->bEndpointAddress;
 	} else {
BtrLinux
Privacy Overview
