drivers/net/usb: use USB API functions rather than constants
This set of patches introduces calls to the following set of functions:
usb_endpoint_dir_in(epd)
usb_endpoint_dir_out(epd)
usb_endpoint_is_bulk_in(epd)
usb_endpoint_is_bulk_out(epd)
usb_endpoint_is_int_in(epd)
usb_endpoint_is_int_out(epd)
usb_endpoint_num(epd)
usb_endpoint_type(epd)
usb_endpoint_xfer_bulk(epd)
usb_endpoint_xfer_control(epd)
usb_endpoint_xfer_int(epd)
usb_endpoint_xfer_isoc(epd)
In some cases, introducing one of these functions is not possible, and it
just replaces an explicit integer value by one of the following constants:
USB_ENDPOINT_XFER_BULK
USB_ENDPOINT_XFER_CONTROL
USB_ENDPOINT_XFER_INT
USB_ENDPOINT_XFER_ISOC
In drivers/net/wireless/zd1211rw/zd_usb.c the code:
(endpoint->bEndpointAddress & USB_TYPE_MASK) == USB_DIR_OUT
is suspicious.  If it is intended to use USB_ENDPOINT_DIR_MASK rather than
USB_TYPE_MASK, then the whole conditional test could be converted to a call
to usb_endpoint_is_bulk_in.
An extract of the semantic patch that makes these changes is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@r1@ struct usb_endpoint_descriptor *epd; @@
- ((epd->bmAttributes & \(USB_ENDPOINT_XFERTYPE_MASK\|3\)) ==
- \(USB_ENDPOINT_XFER_CONTROL\|0\))
+ usb_endpoint_xfer_control(epd)
@r5@ struct usb_endpoint_descriptor *epd; @@
- ((epd->bEndpointAddress & \(USB_ENDPOINT_DIR_MASK\|0x80\)) ==
-  \(USB_DIR_IN\|0x80\))
+ usb_endpoint_dir_in(epd)
@inc@
#include
@depends on !inc && (r1||r5)@
+ #include
  #include
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/usb/hso.c                  | 2 +-
 drivers/net/wireless/zd1211rw/zd_usb.c | 3 +--
 2 files changed, 2 insertions(+), 3 deletions(-)
diff --git a/drivers/net/usb/hso.c b/drivers/net/usb/hso.c
index 198ce3c..9f7896a 100644
--- a/drivers/net/usb/hso.c
+++ b/drivers/net/usb/hso.c
@@ -2831,7 +2831,7 @@ static struct usb_endpoint_descriptor *hso_get_ep(struct usb_interface *intf,
 	for (i = 0; i < iface->desc.bNumEndpoints; i++) {
 		endp = &iface->endpoint[i].desc;
 		if (((endp->bEndpointAddress & USB_ENDPOINT_DIR_MASK) == dir) &&
-		    ((endp->bmAttributes & USB_ENDPOINT_XFERTYPE_MASK) == type))
+		    (usb_endpoint_type(endp) == type))
 			return endp;
diff --git a/drivers/net/wireless/zd1211rw/zd_usb.c b/drivers/net/wireless/zd1211rw/zd_usb.c
index 04c1396..b5db57d 100644
--- a/drivers/net/wireless/zd1211rw/zd_usb.c
+++ b/drivers/net/wireless/zd1211rw/zd_usb.c
@@ -1065,8 +1065,7 @@ static int eject_installer(struct usb_interface *intf)
 	/* Find bulk out endpoint */
 	endpoint = &iface_desc->endpoint[1].desc;
 	if ((endpoint->bEndpointAddress & USB_TYPE_MASK) == USB_DIR_OUT &&
-	    (endpoint->bmAttributes & USB_ENDPOINT_XFERTYPE_MASK) ==
-	    USB_ENDPOINT_XFER_BULK) {
+	    usb_endpoint_xfer_bulk(endpoint)) {
 		bulk_out_ep = endpoint->bEndpointAddress;
 	} else {
 		dev_err(&udev->dev,
BtrLinux
Privacy Overview
