drivers/net/usb: Use kmemdup
Use kmemdup when some other buffer is immediately copied into the
allocated region.
A simplified version of the semantic patch that makes this change is as
follows: (http://coccinelle.lip6.fr/)
expression from,to,size,flag;
statement S;
-  to = \(kmalloc\|kzalloc\)(size,flag);
+  to = kmemdup(from,size,flag);
   if (to==NULL || ...) S
-  memcpy(to, from, size);
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/usb/pegasus.c | 6 ++----
 1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/drivers/net/usb/pegasus.c b/drivers/net/usb/pegasus.c
index 1cd17d2..974d17f 100644
--- a/drivers/net/usb/pegasus.c
+++ b/drivers/net/usb/pegasus.c
@@ -203,13 +203,12 @@ static int set_registers(pegasus_t * pegasus, __u16 indx, __u16 size,
 	char *buffer;
 	DECLARE_WAITQUEUE(wait, current);
-	buffer = kmalloc(size, GFP_KERNEL);
+	buffer = kmemdup(data, size, GFP_KERNEL);
 	if (!buffer) {
 		netif_warn(pegasus, drv, pegasus->net,
 			   "out of memory in %s\n", __func__);
 		return -ENOMEM;
-	memcpy(buffer, data, size);
 	add_wait_queue(&pegasus->ctrl_wait, &wait);
 	set_current_state(TASK_UNINTERRUPTIBLE);
@@ -255,13 +254,12 @@ static int set_register(pegasus_t * pegasus, __u16 indx, __u8 data)
 	char *tmp;
-	tmp = kmalloc(1, GFP_KERNEL);
+	tmp = kmemdup(&data, 1, GFP_KERNEL);
 	if (!tmp) {
 		return -ENOMEM;
-	memcpy(tmp, &data, 1);
 	while (pegasus->flags & ETH_REGS_CHANGED)
