drivers/net/usb: Correct code taking the size of a pointer
sizeof(dev->dev_addr) is the size of a pointer.  A few lines above, the
size of this field is obtained using netdev->addr_len for a call to memcpy,
so do the same here.
A simplified version of the semantic patch that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
expression *x;
expression f;
type T;
*f(...,(T)x,...)
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/usb/rtl8150.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/usb/rtl8150.c b/drivers/net/usb/rtl8150.c
index b091e20..f14d225 100644
--- a/drivers/net/usb/rtl8150.c
+++ b/drivers/net/usb/rtl8150.c
@@ -324,7 +324,7 @@ static int rtl8150_set_mac_address(struct net_device *netdev, void *p)
 		dbg("%02X:", netdev->dev_addr[i]);
 	dbg("%02X\n", netdev->dev_addr[i]);
 	/* Set the IDR registers. */
-	set_registers(dev, IDR, sizeof(netdev->dev_addr), netdev->dev_addr);
+	set_registers(dev, IDR, netdev->addr_len, netdev->dev_addr);
 #ifdef EEPROM_WRITE
 	u8 cr;
BtrLinux
Privacy Overview
