drivers/net/typhoon.c: delete double assignment
Delete successive assignments to the same location.  The current definition
does not initialize the respRing structure, which has the same type as the
cmdRing structure, so initialize that one instead.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
expression i;
*i = ...;
 i = ...;
Signed-off-by: Julia Lawall
Acked-by: David Dillow
Signed-off-by: David S. Miller
 drivers/net/typhoon.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/typhoon.c b/drivers/net/typhoon.c
index b550da0..5b83c3f 100644
--- a/drivers/net/typhoon.c
+++ b/drivers/net/typhoon.c
@@ -1300,7 +1300,7 @@ typhoon_init_rings(struct typhoon *tp)
 	tp->rxHiRing.lastWrite = 0;
 	tp->rxBuffRing.lastWrite = 0;
 	tp->cmdRing.lastWrite = 0;
-	tp->cmdRing.lastWrite = 0;
+	tp->respRing.lastWrite = 0;
 	tp->txLoRing.lastRead = 0;
 	tp->txHiRing.lastRead = 0;
BtrLinux
Privacy Overview
