drivers/net/smsc9420.c: remove exceptional & on function name
In this file, function names are otherwise used as pointers without &.
A simplified version of the semantic patch that makes this change is as
follows: (http://coccinelle.lip6.fr/)
@r@
identifier f;
f(...) { ... }
identifier r.f;
- &f
+ f
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
drivers/net/smsc9420.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/smsc9420.c b/drivers/net/smsc9420.c
index b4909a2..92e2bbe 100644
--- a/drivers/net/smsc9420.c
+++ b/drivers/net/smsc9420.c
@@ -1161,7 +1161,7 @@ static int smsc9420_mii_probe(struct net_device *dev)
phydev->phy_id);
phydev = phy_connect(dev, dev_name(&phydev->dev),
- &smsc9420_phy_adjust_link, 0, PHY_INTERFACE_MODE_MII);
+ smsc9420_phy_adjust_link, 0, PHY_INTERFACE_MODE_MII);
if (IS_ERR(phydev)) {
pr_err("%s: Could not attach to PHY\n", dev->name); |
phydev->phy_id);
