drivers/net/smsc911x.c: Fix resource size off by 1 error
The call resource_size(res) returns res->end - res->start + 1 and thus the
second change is semantics-preserving.  res_size is then used as the second
argument of a call to request_mem_region, and the memory allocated by this
call appears to be the same as what is released in the two calls to
release_mem_region.  So the size argument for those calls should be
resource_size(size) as well.  Alternatively, in the second call to
release_mem_region, the second argument could be res_size, as that variable
has already been initialized at the point of this call.
The problem was found using the following semantic patch:
(http://www.emn.fr/x-info/coccinelle/)
struct resource *res;
- (res->end - res->start) + 1
+ resource_size(res)
- res->end - res->start
+ BAD(resource_size(res))
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/smsc911x.c | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/net/smsc911x.c b/drivers/net/smsc911x.c
index b60639b..66067f9 100644
--- a/drivers/net/smsc911x.c
+++ b/drivers/net/smsc911x.c
@@ -1938,7 +1938,7 @@ static int __devexit smsc911x_drv_remove(struct platform_device *pdev)
 	if (!res)
 		res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
-	release_mem_region(res->start, res->end - res->start);
+	release_mem_region(res->start, resource_size(res));
 	iounmap(pdata->ioaddr);
@@ -1976,7 +1976,7 @@ static int __devinit smsc911x_drv_probe(struct platform_device *pdev)
 		retval = -ENODEV;
 		goto out_0;
-	res_size = res->end - res->start + 1;
+	res_size = resource_size(res);
 	irq_res = platform_get_resource(pdev, IORESOURCE_IRQ, 0);
 	if (!irq_res) {
@@ -2104,7 +2104,7 @@ out_unmap_io_3:
 out_free_netdev_2:
 	free_netdev(dev);
 out_release_io_1:
 out_0:
 	return retval;
 	if (!res)
 		retval = -ENODEV;
 		goto out_0;
 	if (!irq_res) {
 out_free_netdev_2:
 	free_netdev(dev);
 out_release_io_1:
 out_0:
 	return retval;
