drivers/net/niu.c: adjust array index
Convert array index from the loop bound to the loop index.
A simplified version of the semantic patch that fixes this problem is as
follows: (http://coccinelle.lip6.fr/)
expression e1,e2,ar;
for(e1 = 0; e1 < e2; e1++) { <...
  ar[
- e2
+ e1
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/niu.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/net/niu.c b/drivers/net/niu.c
index cd6c231..ed47585 100644
--- a/drivers/net/niu.c
+++ b/drivers/net/niu.c
@@ -9201,7 +9201,7 @@ static int __devinit niu_ldg_init(struct niu *np)
 	first_chan = 0;
 	for (i = 0; i < port; i++)
-		first_chan += parent->rxchan_per_port[port];
+		first_chan += parent->rxchan_per_port[i];
 	num_chan = parent->rxchan_per_port[port];
 	for (i = first_chan; i < (first_chan + num_chan); i++) {
@@ -9217,7 +9217,7 @@ static int __devinit niu_ldg_init(struct niu *np)
 	first_chan = 0;
-		first_chan += parent->txchan_per_port[port];
+		first_chan += parent->txchan_per_port[i];
 	num_chan = parent->txchan_per_port[port];
 		err = niu_ldg_assign_ldn(np, parent,
BtrLinux
Privacy Overview
