drivers/net/irda/mcs7780.c: fix error return code
Author: Peter Senna Tschudin <peter.senna@gmail.com>
The function mcs_probe() return 0 for success and negative value
for most of its internal tests failures. There is one exception
that is error case going to error2:. For this error case, the
function abort its success execution path, but returns non negative
value, making it difficult for a caller function to notice the error.
This patch fixes the error case that do not return negative value.
A simplified version of the semantic match that finds this problem is
as follows: (http://coccinelle.lip6.fr/)
if@p1 (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret@p1 = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Peter Senna Tschudin
Signed-off-by: David S. Miller
 drivers/net/irda/mcs7780.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/net/irda/mcs7780.c b/drivers/net/irda/mcs7780.c
index 1a00b59..f07c340 100644
--- a/drivers/net/irda/mcs7780.c
+++ b/drivers/net/irda/mcs7780.c
@@ -920,8 +920,10 @@ static int mcs_probe(struct usb_interface *intf,
 	ndev->netdev_ops = &mcs_netdev_ops;
-	if (!intf->cur_altsetting)
+	if (!intf->cur_altsetting) {
+		ret = -ENOMEM;
 		goto error2;
 	ret = mcs_find_endpoints(mcs, intf->cur_altsetting->endpoint,
 				 intf->cur_altsetting->desc.bNumEndpoints);
BtrLinux
Privacy Overview
