drivers/net/irda: Eliminate memory leak
dev_alloc_skb allocates some memory, so that memory should be freed before
leaving the function in an error case.
Corrected some typos in a nearby comment as well.
A simplified version of the semantic match that finds this problem is:
(http://coccinelle.lip6.fr/)
@r exists@
local idexpression x;
expression E;
identifier f1;
iterator I;
x = dev_alloc_skb(...);
<... when != x
     when != true (x == NULL || ...)
     when != if (...) { <+...x...+> }
     when != I (...) { <+...x...+> }
 x == NULL
 x == E
 x->f1
* return ...;
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/irda/via-ircc.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/net/irda/via-ircc.c b/drivers/net/irda/via-ircc.c
index b0a6cd8..67c0ad4 100644
--- a/drivers/net/irda/via-ircc.c
+++ b/drivers/net/irda/via-ircc.c
@@ -1182,12 +1182,13 @@ F01_E */
 		skb = dev_alloc_skb(len + 1 - 4);
-		 * if frame size,data ptr,or skb ptr are wrong ,the get next
+		 * if frame size, data ptr, or skb ptr are wrong, then get next
 		 * entry.
 		if ((skb == NULL) || (skb->data == NULL) ||
 		    (self->rx_buff.data == NULL) || (len < 6)) {
 			self->netdev->stats.rx_dropped++;
+			kfree_skb(skb);
 			return TRUE;
 		skb_reserve(skb, 1);
BtrLinux
Privacy Overview
