drivers/net/hamradio/6pack.c: move a dereference below a NULL test
In each case, if the NULL test is necessary, then the dereference should be
moved below the NULL test.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
type T;
expression E;
identifier i,fld;
statement S;
- T i = E->fld;
+ T i;
  ... when != E
      when != i
  if (E == NULL) S
+ i = E->fld;
Signed-off-by: Julia Lawall
Signed-off-by: Andrew Morton
Signed-off-by: David S. Miller
 drivers/net/hamradio/6pack.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/net/hamradio/6pack.c b/drivers/net/hamradio/6pack.c
index 50f1e17..2d40898 100644
--- a/drivers/net/hamradio/6pack.c
+++ b/drivers/net/hamradio/6pack.c
@@ -717,11 +717,12 @@ static int sixpack_ioctl(struct tty_struct *tty, struct file *file,
 	unsigned int cmd, unsigned long arg)
 	struct sixpack *sp = sp_get(tty);
-	struct net_device *dev = sp->dev;
+	struct net_device *dev;
 	unsigned int tmp, err;
 	if (!sp)
 		return -ENXIO;
+	dev = sp->dev;
 	switch(cmd) {
 	case SIOCGIFNAME:
BtrLinux
Privacy Overview
