drivers/net/hamradio: Adjust confusing if indentation
Indent the branch of an if.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@r disable braces4@
position p1,p2;
statement S1,S2;
if (...) { ... }
if (...) S1@p1 S2@p2
@script:python@
p1 << r.p1;
p2 << r.p2;
if (p1[0].column == p2[0].column):
  cocci.print_main("branch",p1)
  cocci.print_secs("after",p2)
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/hamradio/scc.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/net/hamradio/scc.c b/drivers/net/hamradio/scc.c
index 9f64c86..3365581 100644
--- a/drivers/net/hamradio/scc.c
+++ b/drivers/net/hamradio/scc.c
@@ -1069,7 +1069,8 @@ static void scc_tx_done(struct scc_channel *scc)
 		case KISS_DUPLEX_LINK:
 			scc->stat.tx_state = TXS_IDLE2;
 			if (scc->kiss.idletime != TIMER_OFF)
-			scc_start_tx_timer(scc, t_idle, scc->kiss.idletime*100);
+				scc_start_tx_timer(scc, t_idle,
+						   scc->kiss.idletime*100);
 			break;
 		case KISS_DUPLEX_OPTIMA:
 			scc_notify(scc, HWEV_ALL_SENT);
BtrLinux
Privacy Overview
