drivers/net/fs_enet: remove null pointer dereference
The following code appears in the function fs_init_instance in the file drivers/net/fs_enet/fs_enet-main.c.
	if (fep->ops == NULL) {
		printk(KERN_ERR DRV_MODULE_NAME
		       ": %s No matching ops found (%d).\n",
		       ndev->name, fpi->fs_no);
		err = -EINVAL;
		goto err;
This code implies that at the point of err, fep->ops can be NULL, so an
extra test is needed before dereferencing this value.
This problem was found using the following semantic match
(http://www.emn.fr/x-info/coccinelle/)
expression E, E1;
identifier f;
statement S1,S2,S3;
* if (E == NULL)
  ... when != if (E == NULL) S1 else S2
      when != E = E1
* E->f
  ... when any
  return ...;
else S3
Signed-off-by: Julia Lawall
Signed-off-by: Jeff Garzik
 drivers/net/fs_enet/fs_enet-main.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/fs_enet/fs_enet-main.c b/drivers/net/fs_enet/fs_enet-main.c
index 67b4b07..a5baaf5 100644
--- a/drivers/net/fs_enet/fs_enet-main.c
+++ b/drivers/net/fs_enet/fs_enet-main.c
@@ -1093,7 +1093,7 @@ err:
 		if (registered)
 			unregister_netdev(ndev);
-		if (fep != NULL) {
+		if (fep && fep->ops) {
 			(*fep->ops->free_bd)(ndev);
 			(*fep->ops->cleanup_data)(ndev);
BtrLinux
Privacy Overview
