drivers/net/ethernet/tundra/tsi108_eth.c: add missing iounmap
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Add missing iounmap in error handling code, in a case where the function
already preforms iounmap on some other execution path.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
expression e;
statement S,S1;
int ret;
e = \(ioremap\|ioremap_nocache\)(...)
... when != iounmap(e)
if (<+...e...+>) S
... when any
    when != iounmap(e)
*if (...)
   { ... when != iounmap(e)
     return ...; }
... when any
iounmap(e);
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/ethernet/tundra/tsi108_eth.c | 6 ++++--
 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/drivers/net/ethernet/tundra/tsi108_eth.c b/drivers/net/ethernet/tundra/tsi108_eth.c
index a9ce01ba..164fb77 100644
--- a/drivers/net/ethernet/tundra/tsi108_eth.c
+++ b/drivers/net/ethernet/tundra/tsi108_eth.c
@@ -1604,7 +1604,7 @@ tsi108_init_one(struct platform_device *pdev)
 	data->phyregs = ioremap(einfo->phyregs, 0x400);
 	if (NULL == data->phyregs) {
 		err = -ENOMEM;
-		goto regs_fail;
+		goto phyregs_fail;
 /* MII setup */
 	data->mii_if.dev = dev;
@@ -1663,9 +1663,11 @@ tsi108_init_one(struct platform_device *pdev)
 	return 0;
 register_fail:
-	iounmap(data->regs);
 	iounmap(data->phyregs);
+phyregs_fail:
+	iounmap(data->regs);
 regs_fail:
 	free_netdev(dev);
 	return err;
BtrLinux
Privacy Overview
