drivers/net/ethernet/qlogic/qlcnic/qlcnic_main.c: fix error return code
Author: Peter Senna Tschudin <peter.senna@gmail.com>
The function qlcnic_probe() return 0 for success and negative value
for most of its internal tests failures. There is one exception
that is error case going to err_out_free_netdev:. For this error case,
the function abort its success execution path, but returns non negative
value, making it difficult for a caller function to notice the error.
This patch fixes the error case that do not return negative value.
This was found by Coccinelle, but the code change was made by hand.
This patch is not robot generated.
A simplified version of the semantic match that finds this problem is
as follows: (http://coccinelle.lip6.fr/)
if@p1 (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret@p1 = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Peter Senna Tschudin
Signed-off-by: David S. Miller
 drivers/net/ethernet/qlogic/qlcnic/qlcnic_main.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/net/ethernet/qlogic/qlcnic/qlcnic_main.c b/drivers/net/ethernet/qlogic/qlcnic/qlcnic_main.c
index 473ce13..24ad17e 100644
--- a/drivers/net/ethernet/qlogic/qlcnic/qlcnic_main.c
+++ b/drivers/net/ethernet/qlogic/qlcnic/qlcnic_main.c
@@ -1601,7 +1601,8 @@ qlcnic_probe(struct pci_dev *pdev, const struct pci_device_id *ent)
 	adapter->netdev  = netdev;
 	adapter->pdev    = pdev;
-	if (qlcnic_alloc_adapter_resources(adapter))
+	err = qlcnic_alloc_adapter_resources(adapter);
+	if (err)
 		goto err_out_free_netdev;
 	adapter->dev_rst_time = jiffies;
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
