drivers/net/ehea: Remove redundant test
In each case, vpage is checked not to be NULL just after it is initialized
at the beginning of each loop iteration.
A simplified version of the semantic patch that makes this change is as
follows: (http://www.emn.fr/x-info/coccinelle/)
@r exists@
local idexpression x;
expression E;
position p1,p2;
if (x@p1 == NULL || ...) { ... when forall
   return ...; }
... when != \(x=E\|x--\|x++\|--x\|++x\|x-=E\|x+=E\|x|=E\|x&=E\|&x\)
x@p2 == NULL
x@p2 != NULL
// another path to the test that is not through p1?
@s exists@
local idexpression r.x;
position r.p1,r.p2;
... when != x@p1
x@p2 == NULL
x@p2 != NULL
@fix depends on !s@
position r.p1,r.p2;
expression x,E;
statement S1,S2;
- if ((x@p2 != NULL) || ...)
  S1
- if ((x@p2 == NULL) && ...) S1
- BUG_ON(x@p2 == NULL);
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/ehea/ehea_qmr.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/net/ehea/ehea_qmr.c b/drivers/net/ehea/ehea_qmr.c
index 3c0ec82..e8c952b 100644
--- a/drivers/net/ehea/ehea_qmr.c
+++ b/drivers/net/ehea/ehea_qmr.c
@@ -182,7 +182,7 @@ struct ehea_cq *ehea_create_cq(struct ehea_adapter *adapter,
 				goto out_kill_hwq;
 		} else {
-			if ((hret != H_PAGE_REGISTERED) || (!vpage)) {
+			if (hret != H_PAGE_REGISTERED) {
 				ehea_error("CQ: registration of page failed "
 					   "hret=%lx\n", hret);
 				goto out_kill_hwq;
@@ -303,7 +303,7 @@ struct ehea_eq *ehea_create_eq(struct ehea_adapter *adapter,
 				goto out_kill_hwq;
 		} else {
 				goto out_kill_hwq;
BtrLinux
Privacy Overview
