drivers/net/cs89x0.c: Avoid using magic number in set_dma_mode
The constant DMA_RX_MODE is defined to be 0x14 in the local include file
cs89x0.h.  Since a constant with the same name is used elsewhere with
set_dma_mode, it seems likely that this constant could be used here.
The semantic match that finds this problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@@ expression E1; identifier I; constant int C; @@
set_dma_mode(E1,I,...)
*set_dma_mode(E1,C,...)
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/cs89x0.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/cs89x0.c b/drivers/net/cs89x0.c
index b5f553a..e594897 100644
--- a/drivers/net/cs89x0.c
+++ b/drivers/net/cs89x0.c
@@ -1367,7 +1367,7 @@ net_open(struct net_device *dev)
 			spin_lock_irqsave(&lp->lock, flags);
 			disable_dma(dev->dma);
 			clear_dma_ff(dev->dma);
-			set_dma_mode(dev->dma, 0x14); /* auto_init as well */
+			set_dma_mode(dev->dma, DMA_RX_MODE); /* auto_init as well */
 			set_dma_addr(dev->dma, isa_virt_to_bus(lp->dma_buff));
 			set_dma_count(dev->dma, lp->dmasize*1024);
 			enable_dma(dev->dma);
BtrLinux
Privacy Overview
