drivers/net/can/flexcan.c: add missing clk_put
The failed_get label is used after the call to clk_get has succeeded, so it
should be moved up above the call to clk_put.
The failed_req labels doesn't do anything different than failed_get, so
delete it.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
@r exists@
expression e1,e2;
statement S;
e1 = clk_get@p1(...);
... when != e1 = e2
    when != clk_put(e1)
    when any
if (...) { ... when != clk_put(e1)
               when != if (...) { ... clk_put(e1) ... }
* return@p3 ...;
 } else S
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/can/flexcan.c | 5 ++---
 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/drivers/net/can/flexcan.c b/drivers/net/can/flexcan.c
index d499056..1767811 100644
--- a/drivers/net/can/flexcan.c
+++ b/drivers/net/can/flexcan.c
@@ -923,7 +923,7 @@ static int __devinit flexcan_probe(struct platform_device *pdev)
 	mem_size = resource_size(mem);
 	if (!request_mem_region(mem->start, mem_size, pdev->name)) {
 		err = -EBUSY;
-		goto failed_req;
+		goto failed_get;
 	base = ioremap(mem->start, mem_size);
@@ -977,9 +977,8 @@ static int __devinit flexcan_probe(struct platform_device *pdev)
 	iounmap(base);
  failed_map:
 	release_mem_region(mem->start, mem_size);
- failed_req:
-	clk_put(clk);
  failed_get:
+	clk_put(clk);
  failed_clock:
 	return err;
BtrLinux
Privacy Overview
