drivers/net/bonding: Adjust constant name
AD_SHORT_TIMEOUT and AD_STATE_LACP_ACTIVITY have the same value, but
AD_STATE_LACP_ACTIVITY better reflects the intended semantics.
[ J adds: AD_STATE_LACP_ACTIVITY is a value defined by the standard, and
should be set here in accordance with 802.3ad 43.4.12; AD_SHORT_TIMEOUT
is a constant specific to the Linux 802.3ad implementation that happens
to have the same value ]
The semantic match that finds this problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
struct port_params p;
* p.port_state |= AD_SHORT_TIMEOUT
Signed-off-by: Julia Lawall
Signed-off-by: Jay Vosburgh
Signed-off-by: David S. Miller
 drivers/net/bonding/bond_3ad.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/net/bonding/bond_3ad.c b/drivers/net/bonding/bond_3ad.c
index 0e7dfe0..be799d2 100644
--- a/drivers/net/bonding/bond_3ad.c
+++ b/drivers/net/bonding/bond_3ad.c
@@ -1109,7 +1109,8 @@ static void ad_rx_machine(struct lacpdu *lacpdu, struct port *port)
 			//mux machine in case of EXPIRED even if LINK_DOWN didn't arrive for the port.
 			port->partner_oper.port_state &= ~AD_STATE_SYNCHRONIZATION;
 			port->sm_vars &= ~AD_PORT_MATCHED;
-			port->partner_oper.port_state |= AD_SHORT_TIMEOUT;
+			port->partner_oper.port_state |=
+				AD_STATE_LACP_ACTIVITY;
 			port->sm_rx_timer_counter = __ad_timer_to_ticks(AD_CURRENT_WHILE_TIMER, (u16)(AD_SHORT_TIMEOUT));
 			port->actor_oper_port_state |= AD_STATE_EXPIRED;
 			break;
BtrLinux
Privacy Overview
