drivers/net: Use kcalloc or kzalloc
Use kcalloc or kzalloc rather than the combination of kmalloc and memset.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
expression x,y,flags;
statement S;
type T;
x =
-   kmalloc
+   kcalloc
-           y * sizeof(T),
+           y, sizeof(T),
                flags);
 if (x == NULL) S
-memset(x, 0, y * sizeof(T));
expression x,size,flags;
statement S;
-x = kmalloc(size,flags);
+x = kzalloc(size,flags);
 if (x == NULL) S
-memset(x, 0, size);
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/ibmveth.c | 3 +--
 drivers/net/ksz884x.c | 3 +--
 2 files changed, 2 insertions(+), 4 deletions(-)
diff --git a/drivers/net/ibmveth.c b/drivers/net/ibmveth.c
index 941be84..7acb3ed 100644
--- a/drivers/net/ibmveth.c
+++ b/drivers/net/ibmveth.c
@@ -200,7 +200,7 @@ static int ibmveth_alloc_buffer_pool(struct ibmveth_buff_pool *pool)
 		return -1;
-	pool->skbuff = kmalloc(sizeof(void*) * pool->size, GFP_KERNEL);
+	pool->skbuff = kcalloc(pool->size, sizeof(void *), GFP_KERNEL);
 	if(!pool->skbuff) {
 		kfree(pool->dma_addr);
@@ -211,7 +211,6 @@ static int ibmveth_alloc_buffer_pool(struct ibmveth_buff_pool *pool)
 		return -1;
-	memset(pool->skbuff, 0, sizeof(void*) * pool->size);
 	memset(pool->dma_addr, 0, sizeof(dma_addr_t) * pool->size);
 	for(i = 0; i < pool->size; ++i) {
diff --git a/drivers/net/ksz884x.c b/drivers/net/ksz884x.c
index cc0bc8a..c80ca64 100644
--- a/drivers/net/ksz884x.c
+++ b/drivers/net/ksz884x.c
@@ -7049,10 +7049,9 @@ static int __init pcidev_init(struct pci_dev *pdev,
 			mib_port_count = SWITCH_PORT_NUM;
 		hw->mib_port_cnt = TOTAL_PORT_NUM;
-		hw->ksz_switch = kmalloc(sizeof(struct ksz_switch), GFP_KERNEL);
+		hw->ksz_switch = kzalloc(sizeof(struct ksz_switch), GFP_KERNEL);
 		if (!hw->ksz_switch)
 			goto pcidev_init_alloc_err;
-		memset(hw->ksz_switch, 0, sizeof(struct ksz_switch));
 		sw = hw->ksz_switch;
BtrLinux
Privacy Overview
