drivers/net: Remove redundant test
In each case, ap is checked not to be NULL a few lines before.
A simplified version of the semantic patch that makes this change is as
follows: (http://www.emn.fr/x-info/coccinelle/)
@r exists@
local idexpression x;
expression E;
position p1,p2;
if (x@p1 == NULL || ...) { ... when forall
   return ...; }
... when != \(x=E\|x--\|x++\|--x\|++x\|x-=E\|x+=E\|x|=E\|x&=E\|&x\)
x@p2 == NULL
x@p2 != NULL
// another path to the test that is not through p1?
@s exists@
local idexpression r.x;
position r.p1,r.p2;
... when != x@p1
x@p2 == NULL
x@p2 != NULL
@fix depends on !s@
position r.p1,r.p2;
expression x,E;
statement S1,S2;
- if ((x@p2 != NULL) || ...)
  S1
- if ((x@p2 == NULL) && ...) S1
- BUG_ON(x@p2 == NULL);
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/ppp_async.c   | 6 ------
 drivers/net/ppp_synctty.c | 6 ------
 2 files changed, 12 deletions(-)
diff --git a/drivers/net/ppp_async.c b/drivers/net/ppp_async.c
index 451bdb5..6567fab 100644
--- a/drivers/net/ppp_async.c
+++ b/drivers/net/ppp_async.c
@@ -293,9 +293,6 @@ ppp_asynctty_ioctl(struct tty_struct *tty, struct file *file,
 	err = -EFAULT;
 	switch (cmd) {
 	case PPPIOCGCHAN:
-		err = -ENXIO;
-		if (!ap)
-			break;
 		err = -EFAULT;
 		if (put_user(ppp_channel_index(&ap->chan), p))
 			break;
@@ -303,9 +300,6 @@ ppp_asynctty_ioctl(struct tty_struct *tty, struct file *file,
 		break;
 	case PPPIOCGUNIT:
-		err = -ENXIO;
-		if (!ap)
-			break;
 		err = -EFAULT;
 		if (put_user(ppp_unit_number(&ap->chan), p))
 			break;
diff --git a/drivers/net/ppp_synctty.c b/drivers/net/ppp_synctty.c
index 801d8f9..1e892b7 100644
--- a/drivers/net/ppp_synctty.c
+++ b/drivers/net/ppp_synctty.c
@@ -333,9 +333,6 @@ ppp_synctty_ioctl(struct tty_struct *tty, struct file *file,
 	err = -EFAULT;
 	switch (cmd) {
 	case PPPIOCGCHAN:
-		err = -ENXIO;
-		if (!ap)
-			break;
 		err = -EFAULT;
 			break;
@@ -343,9 +340,6 @@ ppp_synctty_ioctl(struct tty_struct *tty, struct file *file,
 		break;
 	case PPPIOCGUNIT:
-		err = -ENXIO;
-		if (!ap)
-			break;
 		err = -EFAULT;
 			break;
BtrLinux
Privacy Overview
