drivers/net: remove exceptional & on function name
In this file, function names are otherwise used as pointers without &.
A simplified version of the semantic patch that makes this change is as
follows: (http://coccinelle.lip6.fr/)
@r@
identifier f;
f(...) { ... }
identifier r.f;
- &f
+ f
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/ethoc.c             | 2 +-
 drivers/net/pcmcia/fmvj18x_cs.c | 2 +-
 drivers/net/pcmcia/nmclan_cs.c  | 2 +-
 drivers/net/tokenring/3c359.c   | 3 +--
 drivers/net/tokenring/olympic.c | 4 ++--
 5 files changed, 6 insertions(+), 7 deletions(-)
diff --git a/drivers/net/ethoc.c b/drivers/net/ethoc.c
index f1c5652..96b6dc4 100644
--- a/drivers/net/ethoc.c
+++ b/drivers/net/ethoc.c
@@ -640,7 +640,7 @@ static int ethoc_mdio_probe(struct net_device *dev)
 		return -ENXIO;
-	phy = phy_connect(dev, dev_name(&phy->dev), &ethoc_mdio_poll, 0,
+	phy = phy_connect(dev, dev_name(&phy->dev), ethoc_mdio_poll, 0,
 			PHY_INTERFACE_MODE_GMII);
 	if (IS_ERR(phy)) {
 		dev_err(&dev->dev, "could not attach to PHY\n");
diff --git a/drivers/net/pcmcia/fmvj18x_cs.c b/drivers/net/pcmcia/fmvj18x_cs.c
index 7e01fbd..57e0961 100644
--- a/drivers/net/pcmcia/fmvj18x_cs.c
+++ b/drivers/net/pcmcia/fmvj18x_cs.c
@@ -264,7 +264,7 @@ static int fmvj18x_probe(struct pcmcia_device *link)
     /* Interrupt setup */
     link->irq.Attributes = IRQ_TYPE_DYNAMIC_SHARING|IRQ_HANDLE_PRESENT;
     link->irq.IRQInfo1 = IRQ_LEVEL_ID;
-    link->irq.Handler = &fjn_interrupt;
+    link->irq.Handler = fjn_interrupt;
     link->irq.Instance = dev;
     /* General socket configuration */
diff --git a/drivers/net/pcmcia/nmclan_cs.c b/drivers/net/pcmcia/nmclan_cs.c
index 5ed6339..b12e695 100644
--- a/drivers/net/pcmcia/nmclan_cs.c
+++ b/drivers/net/pcmcia/nmclan_cs.c
@@ -479,7 +479,7 @@ static int nmclan_probe(struct pcmcia_device *link)
     link->io.IOAddrLines = 5;
     link->irq.Attributes = IRQ_TYPE_EXCLUSIVE | IRQ_HANDLE_PRESENT;
-    link->irq.Handler = &mace_interrupt;
+    link->irq.Handler = mace_interrupt;
     link->conf.Attributes = CONF_ENABLE_IRQ;
     link->conf.IntType = INT_MEMORY_AND_IO;
diff --git a/drivers/net/tokenring/3c359.c b/drivers/net/tokenring/3c359.c
index 7241589..cf552d1 100644
--- a/drivers/net/tokenring/3c359.c
+++ b/drivers/net/tokenring/3c359.c
@@ -610,9 +610,8 @@ static int xl_open(struct net_device *dev)
 	u16 switchsettings, switchsettings_eeprom  ;
-	if(request_irq(dev->irq, &xl_interrupt, IRQF_SHARED , "3c359", dev)) {
+	if (request_irq(dev->irq, xl_interrupt, IRQF_SHARED , "3c359", dev))
 		return -EAGAIN;
 	 * Read the information from the EEPROM that we need.
diff --git a/drivers/net/tokenring/olympic.c b/drivers/net/tokenring/olympic.c
index d9ec7f0..df32025 100644
--- a/drivers/net/tokenring/olympic.c
+++ b/drivers/net/tokenring/olympic.c
@@ -445,9 +445,9 @@ static int olympic_open(struct net_device *dev)
 	olympic_init(dev);
-	if(request_irq(dev->irq, &olympic_interrupt, IRQF_SHARED , "olympic", dev)) {
+	if (request_irq(dev->irq, olympic_interrupt, IRQF_SHARED , "olympic",
+			dev))
 		return -EAGAIN;
 #if OLYMPIC_DEBUG
 	printk("BMCTL: %x\n",readl(olympic_mmio+BMCTL_SUM));
BtrLinux
Privacy Overview
