drivers/net: Remove address use from assignments of function pointers
Author: Joe Perches <joe@perches.com>
"foo = &function" is more commonly written "foo = function"
Done with coccinelle script:
@r@
identifier f;
f(...) { ... }
identifier r.f;
- &f
+ f
drivers/net/tehuti.c used a function and struct with the
same name, the function was renamed.
Compile tested x86 only.
Signed-off-by: Joe Perches
Signed-off-by: David S. Miller
 drivers/net/3c503.c                |  8 +++----
 drivers/net/3c515.c                |  2 +-
 drivers/net/3c59x.c                |  2 +-
 drivers/net/atl1e/atl1e_main.c     |  2 +-
 drivers/net/atlx/atl1.c            |  2 +-
 drivers/net/atlx/atl2.c            |  4 ++--
 drivers/net/atp.c                  |  2 +-
 drivers/net/bcm63xx_enet.c         |  2 +-
 drivers/net/cpmac.c                |  2 +-
 drivers/net/declance.c             |  2 +-
 drivers/net/dl2k.c                 |  2 +-
 drivers/net/e1000/e1000_main.c     |  6 ++---
 drivers/net/e1000e/netdev.c        |  4 ++--
 drivers/net/ehea/ehea_main.c       |  6 ++---
 drivers/net/epic100.c              |  2 +-
 drivers/net/fealnx.c               |  4 ++--
 drivers/net/forcedeth.c            |  6 ++---
 drivers/net/hamachi.c              |  2 +-
 drivers/net/hp.c                   |  8 +++----
 drivers/net/hydra.c                |  8 +++----
 drivers/net/igb/igb_main.c         |  4 ++--
 drivers/net/ioc3-eth.c             |  2 +-
 drivers/net/ixgb/ixgb_main.c       |  2 +-
 drivers/net/ixgbe/ixgbe_main.c     |  4 ++--
 drivers/net/ixgbevf/ixgbevf_main.c |  2 +-
 drivers/net/mac8390.c              | 48 +++++++++++++++++++-------------------
 drivers/net/natsemi.c              |  2 +-
 drivers/net/pci-skeleton.c         |  2 +-
 drivers/net/pcmcia/3c574_cs.c      |  2 +-
 drivers/net/pcmcia/3c589_cs.c      |  2 +-
 drivers/net/pcmcia/axnet_cs.c      | 10 ++++----
 drivers/net/pcmcia/pcnet_cs.c      | 16 ++++++-------
 drivers/net/pcmcia/smc91c92_cs.c   |  4 ++--
 drivers/net/rrunner.c              |  2 +-
 drivers/net/sh_eth.c               |  2 +-
 drivers/net/sis900.c               |  2 +-
 drivers/net/sunbmac.c              |  2 +-
 drivers/net/sundance.c             |  2 +-
 drivers/net/sunhme.c               |  2 +-
 drivers/net/sunlance.c             |  2 +-
 drivers/net/tehuti.c               |  8 +++----
 drivers/net/tlan.c                 |  8 +++----
 drivers/net/tulip/dmfe.c           |  2 +-
 drivers/net/tulip/uli526x.c        |  2 +-
 drivers/net/tulip/winbond-840.c    |  2 +-
 drivers/net/wan/lmc/lmc_main.c     |  2 +-
 drivers/net/wd.c                   |  8 +++----
 drivers/net/wireless/ray_cs.c      | 12 +++++-----
 drivers/net/yellowfin.c            |  2 +-
 49 files changed, 118 insertions(+), 118 deletions(-)
diff --git a/drivers/net/3c503.c b/drivers/net/3c503.c
index baac246..4777a1c 100644
--- a/drivers/net/3c503.c
+++ b/drivers/net/3c503.c
@@ -337,10 +337,10 @@ el2_probe1(struct net_device *dev, int ioaddr)
     /* Finish setting the board's parameters. */
     ei_status.stop_page = EL2_MB1_STOP_PG;
     ei_status.word16 = wordlength;
-    ei_status.reset_8390 = &el2_reset_8390;
-    ei_status.get_8390_hdr = &el2_get_8390_hdr;
-    ei_status.block_input = &el2_block_input;
-    ei_status.block_output = &el2_block_output;
+    ei_status.reset_8390 = el2_reset_8390;
+    ei_status.get_8390_hdr = el2_get_8390_hdr;
+    ei_status.block_input = el2_block_input;
+    ei_status.block_output = el2_block_output;
     if (dev->irq == 2)
 	dev->irq = 9;
diff --git a/drivers/net/3c515.c b/drivers/net/3c515.c
index 3bba835..8a6eb0c 100644
--- a/drivers/net/3c515.c
+++ b/drivers/net/3c515.c
@@ -734,7 +734,7 @@ static int corkscrew_open(struct net_device *dev)
 		init_timer(&vp->timer);
 		vp->timer.expires = jiffies + media_tbl[dev->if_port].wait;
 		vp->timer.data = (unsigned long) dev;
-		vp->timer.function = &corkscrew_timer;	/* timer handler */
+		vp->timer.function = corkscrew_timer;	/* timer handler */
 		add_timer(&vp->timer);
 	} else
 		dev->if_port = vp->default_media;
diff --git a/drivers/net/3c59x.c b/drivers/net/3c59x.c
index c754d88..7a01588 100644
--- a/drivers/net/3c59x.c
+++ b/drivers/net/3c59x.c
@@ -1738,7 +1738,7 @@ vortex_open(struct net_device *dev)
 	/* Use the now-standard shared IRQ implementation. */
 	if ((retval = request_irq(dev->irq, vp->full_bus_master_rx ?
-				&boomerang_interrupt : &vortex_interrupt, IRQF_SHARED, dev->name, dev))) {
+				boomerang_interrupt : vortex_interrupt, IRQF_SHARED, dev->name, dev))) {
 		pr_err("%s: Could not reserve IRQ %d\n", dev->name, dev->irq);
 		goto err;
diff --git a/drivers/net/atl1e/atl1e_main.c b/drivers/net/atl1e/atl1e_main.c
index 1acea57..1ae44bb 100644
--- a/drivers/net/atl1e/atl1e_main.c
+++ b/drivers/net/atl1e/atl1e_main.c
@@ -2316,7 +2316,7 @@ static int __devinit atl1e_probe(struct pci_dev *pdev,
 	netif_napi_add(netdev, &adapter->napi, atl1e_clean, 64);
 	init_timer(&adapter->phy_config_timer);
-	adapter->phy_config_timer.function = &atl1e_phy_config;
+	adapter->phy_config_timer.function = atl1e_phy_config;
 	adapter->phy_config_timer.data = (unsigned long) adapter;
 	/* get user settings */
diff --git a/drivers/net/atlx/atl1.c b/drivers/net/atlx/atl1.c
index 63b9ba0..5837b01 100644
--- a/drivers/net/atlx/atl1.c
+++ b/drivers/net/atlx/atl1.c
@@ -3036,7 +3036,7 @@ static int __devinit atl1_probe(struct pci_dev *pdev,
 	netif_carrier_off(netdev);
 	netif_stop_queue(netdev);
-	setup_timer(&adapter->phy_config_timer, &atl1_phy_config,
+	setup_timer(&adapter->phy_config_timer, atl1_phy_config,
 		    (unsigned long)adapter);
 	adapter->phy_timer_pending = false;
diff --git a/drivers/net/atlx/atl2.c b/drivers/net/atlx/atl2.c
index 8da8738..07adc84 100644
--- a/drivers/net/atlx/atl2.c
+++ b/drivers/net/atlx/atl2.c
@@ -1444,11 +1444,11 @@ static int __devinit atl2_probe(struct pci_dev *pdev,
 	atl2_check_options(adapter);
 	init_timer(&adapter->watchdog_timer);
-	adapter->watchdog_timer.function = &atl2_watchdog;
+	adapter->watchdog_timer.function = atl2_watchdog;
 	adapter->watchdog_timer.data = (unsigned long) adapter;
-	adapter->phy_config_timer.function = &atl2_phy_config;
+	adapter->phy_config_timer.function = atl2_phy_config;
 	INIT_WORK(&adapter->reset_task, atl2_reset_task);
diff --git a/drivers/net/atp.c b/drivers/net/atp.c
index bd2f9d3..dfd96b2 100644
--- a/drivers/net/atp.c
+++ b/drivers/net/atp.c
@@ -445,7 +445,7 @@ static int net_open(struct net_device *dev)
 	init_timer(&lp->timer);
 	lp->timer.expires = jiffies + TIMED_CHECKER;
 	lp->timer.data = (unsigned long)dev;
-	lp->timer.function = &atp_timed_checker;    /* timer handler */
+	lp->timer.function = atp_timed_checker;    /* timer handler */
 	add_timer(&lp->timer);
 	netif_start_queue(dev);
diff --git a/drivers/net/bcm63xx_enet.c b/drivers/net/bcm63xx_enet.c
index e2f70c3..ecfef24 100644
--- a/drivers/net/bcm63xx_enet.c
+++ b/drivers/net/bcm63xx_enet.c
@@ -798,7 +798,7 @@ static int bcm_enet_open(struct net_device *dev)
 		snprintf(phy_id, sizeof(phy_id), PHY_ID_FMT,
 			 priv->mac_id ? "1" : "0", priv->phy_id);
-		phydev = phy_connect(dev, phy_id, &bcm_enet_adjust_phy_link, 0,
+		phydev = phy_connect(dev, phy_id, bcm_enet_adjust_phy_link, 0,
 				     PHY_INTERFACE_MODE_MII);
 		if (IS_ERR(phydev)) {
diff --git a/drivers/net/cpmac.c b/drivers/net/cpmac.c
index 8e142aa..5a5af1c 100644
--- a/drivers/net/cpmac.c
+++ b/drivers/net/cpmac.c
@@ -1175,7 +1175,7 @@ static int __devinit cpmac_probe(struct platform_device *pdev)
 	snprintf(priv->phy_name, MII_BUS_ID_SIZE, PHY_ID_FMT,
 						mdio_bus_id, phy_id);
-	priv->phy = phy_connect(dev, priv->phy_name, &cpmac_adjust_link, 0,
+	priv->phy = phy_connect(dev, priv->phy_name, cpmac_adjust_link, 0,
 	if (IS_ERR(priv->phy)) {
diff --git a/drivers/net/declance.c b/drivers/net/declance.c
index d7de376..219eb5a 100644
--- a/drivers/net/declance.c
+++ b/drivers/net/declance.c
@@ -1255,7 +1255,7 @@ static int __devinit dec_lance_probe(struct device *bdev, const int type)
 	init_timer(&lp->multicast_timer);
 	lp->multicast_timer.data = (unsigned long) dev;
-	lp->multicast_timer.function = &lance_set_multicast_retry;
+	lp->multicast_timer.function = lance_set_multicast_retry;
 	ret = register_netdev(dev);
 	if (ret) {
diff --git a/drivers/net/dl2k.c b/drivers/net/dl2k.c
index a2f238d..e1a8216 100644
--- a/drivers/net/dl2k.c
+++ b/drivers/net/dl2k.c
@@ -465,7 +465,7 @@ rio_open (struct net_device *dev)
 	init_timer (&np->timer);
 	np->timer.expires = jiffies + 1*HZ;
 	np->timer.data = (unsigned long) dev;
-	np->timer.function = &rio_timer;
+	np->timer.function = rio_timer;
 	add_timer (&np->timer);
 	/* Start Tx/Rx */
diff --git a/drivers/net/e1000/e1000_main.c b/drivers/net/e1000/e1000_main.c
index 5cc39ed..3e8ac4b 100644
--- a/drivers/net/e1000/e1000_main.c
+++ b/drivers/net/e1000/e1000_main.c
@@ -962,15 +962,15 @@ static int __devinit e1000_probe(struct pci_dev *pdev,
 	e1000_get_bus_info(hw);
 	init_timer(&adapter->tx_fifo_stall_timer);
-	adapter->tx_fifo_stall_timer.function = &e1000_82547_tx_fifo_stall;
+	adapter->tx_fifo_stall_timer.function = e1000_82547_tx_fifo_stall;
 	adapter->tx_fifo_stall_timer.data = (unsigned long)adapter;
-	adapter->watchdog_timer.function = &e1000_watchdog;
+	adapter->watchdog_timer.function = e1000_watchdog;
 	init_timer(&adapter->phy_info_timer);
-	adapter->phy_info_timer.function = &e1000_update_phy_info;
+	adapter->phy_info_timer.function = e1000_update_phy_info;
 	adapter->phy_info_timer.data = (unsigned long)adapter;
 	INIT_WORK(&adapter->reset_task, e1000_reset_task);
diff --git a/drivers/net/e1000e/netdev.c b/drivers/net/e1000e/netdev.c
index 2b8ef44..5f3eac6 100644
--- a/drivers/net/e1000e/netdev.c
+++ b/drivers/net/e1000e/netdev.c
@@ -5745,11 +5745,11 @@ static int __devinit e1000_probe(struct pci_dev *pdev,
 	adapter->phy_info_timer.data = (unsigned long) adapter;
diff --git a/drivers/net/ehea/ehea_main.c b/drivers/net/ehea/ehea_main.c
index 2b98ee8..043d990 100644
--- a/drivers/net/ehea/ehea_main.c
+++ b/drivers/net/ehea/ehea_main.c
@@ -3721,7 +3721,7 @@ int __init ehea_module_init(void)
 	if (ret)
 		ehea_info("failed registering memory remove notifier");
-	ret = crash_shutdown_register(&ehea_crash_handler);
+	ret = crash_shutdown_register(ehea_crash_handler);
 	if (ret)
 		ehea_info("failed registering crash handler");
@@ -3746,7 +3746,7 @@ out3:
 out2:
 	unregister_memory_notifier(&ehea_mem_nb);
 	unregister_reboot_notifier(&ehea_reboot_nb);
-	crash_shutdown_unregister(&ehea_crash_handler);
+	crash_shutdown_unregister(ehea_crash_handler);
 out:
 	return ret;
@@ -3759,7 +3759,7 @@ static void __exit ehea_module_exit(void)
 	driver_remove_file(&ehea_driver.driver, &driver_attr_capabilities);
 	ibmebus_unregister_driver(&ehea_driver);
-	ret = crash_shutdown_unregister(&ehea_crash_handler);
+	ret = crash_shutdown_unregister(ehea_crash_handler);
 	if (ret)
 		ehea_info("failed unregistering crash handler");
diff --git a/drivers/net/epic100.c b/drivers/net/epic100.c
index 57c8ac0..32543a3 100644
--- a/drivers/net/epic100.c
+++ b/drivers/net/epic100.c
@@ -758,7 +758,7 @@ static int epic_open(struct net_device *dev)
 	init_timer(&ep->timer);
 	ep->timer.expires = jiffies + 3*HZ;
 	ep->timer.data = (unsigned long)dev;
-	ep->timer.function = &epic_timer;				/* timer handler */
+	ep->timer.function = epic_timer;				/* timer handler */
 	add_timer(&ep->timer);
 	return 0;
diff --git a/drivers/net/fealnx.c b/drivers/net/fealnx.c
index d7e8f6b..dd54abe 100644
--- a/drivers/net/fealnx.c
+++ b/drivers/net/fealnx.c
@@ -915,14 +915,14 @@ static int netdev_open(struct net_device *dev)
 	init_timer(&np->timer);
 	np->timer.expires = RUN_AT(3 * HZ);
-	np->timer.function = &netdev_timer;
+	np->timer.function = netdev_timer;
 	/* timer handler */
 	add_timer(&np->timer);
 	init_timer(&np->reset_timer);
 	np->reset_timer.data = (unsigned long) dev;
-	np->reset_timer.function = &reset_timer;
+	np->reset_timer.function = reset_timer;
 	np->reset_timer_armed = 0;
 	return 0;
diff --git a/drivers/net/forcedeth.c b/drivers/net/forcedeth.c
index 4da05b1..6a44fe4 100644
--- a/drivers/net/forcedeth.c
+++ b/drivers/net/forcedeth.c
@@ -5440,13 +5440,13 @@ static int __devinit nv_probe(struct pci_dev *pci_dev, const struct pci_device_i
 	init_timer(&np->oom_kick);
 	np->oom_kick.data = (unsigned long) dev;
-	np->oom_kick.function = &nv_do_rx_refill;	/* timer handler */
+	np->oom_kick.function = nv_do_rx_refill;	/* timer handler */
 	init_timer(&np->nic_poll);
 	np->nic_poll.data = (unsigned long) dev;
-	np->nic_poll.function = &nv_do_nic_poll;	/* timer handler */
+	np->nic_poll.function = nv_do_nic_poll;	/* timer handler */
 	init_timer(&np->stats_poll);
 	np->stats_poll.data = (unsigned long) dev;
-	np->stats_poll.function = &nv_do_stats_poll;	/* timer handler */
+	np->stats_poll.function = nv_do_stats_poll;	/* timer handler */
 	err = pci_enable_device(pci_dev);
 	if (err)
diff --git a/drivers/net/hamachi.c b/drivers/net/hamachi.c
index 49aac70..9a64858 100644
--- a/drivers/net/hamachi.c
+++ b/drivers/net/hamachi.c
@@ -1004,7 +1004,7 @@ static int hamachi_open(struct net_device *dev)
 	init_timer(&hmp->timer);
 	hmp->timer.expires = RUN_AT((24*HZ)/10);			/* 2.4 sec. */
 	hmp->timer.data = (unsigned long)dev;
-	hmp->timer.function = &hamachi_timer;				/* timer handler */
+	hmp->timer.function = hamachi_timer;				/* timer handler */
 	add_timer(&hmp->timer);
 	return 0;
diff --git a/drivers/net/hp.c b/drivers/net/hp.c
index 86ececd..d15d2f2 100644
--- a/drivers/net/hp.c
+++ b/drivers/net/hp.c
@@ -204,10 +204,10 @@ static int __init hp_probe1(struct net_device *dev, int ioaddr)
 	ei_status.rx_start_page = HP_START_PG + TX_PAGES;
 	ei_status.stop_page = wordmode ? HP_16BSTOP_PG : HP_8BSTOP_PG;
-	ei_status.reset_8390 = &hp_reset_8390;
-	ei_status.get_8390_hdr = &hp_get_8390_hdr;
-	ei_status.block_input = &hp_block_input;
-	ei_status.block_output = &hp_block_output;
+	ei_status.reset_8390 = hp_reset_8390;
+	ei_status.get_8390_hdr = hp_get_8390_hdr;
+	ei_status.block_input = hp_block_input;
+	ei_status.block_output = hp_block_output;
 	hp_init_card(dev);
 	retval = register_netdev(dev);
diff --git a/drivers/net/hydra.c b/drivers/net/hydra.c
index 07d8e5b..376e953 100644
--- a/drivers/net/hydra.c
+++ b/drivers/net/hydra.c
@@ -155,10 +155,10 @@ static int __devinit hydra_init(struct zorro_dev *z)
     ei_status.rx_start_page = start_page + TX_PAGES;
-    ei_status.reset_8390 = &hydra_reset_8390;
-    ei_status.block_input = &hydra_block_input;
-    ei_status.block_output = &hydra_block_output;
-    ei_status.get_8390_hdr = &hydra_get_8390_hdr;
+    ei_status.reset_8390 = hydra_reset_8390;
+    ei_status.block_input = hydra_block_input;
+    ei_status.block_output = hydra_block_output;
+    ei_status.get_8390_hdr = hydra_get_8390_hdr;
     ei_status.reg_offset = hydra_offsets;
     dev->netdev_ops = &hydra_netdev_ops;
diff --git a/drivers/net/igb/igb_main.c b/drivers/net/igb/igb_main.c
index 985e37c..d35cc38 100644
--- a/drivers/net/igb/igb_main.c
+++ b/drivers/net/igb/igb_main.c
@@ -1888,9 +1888,9 @@ static int __devinit igb_probe(struct pci_dev *pdev,
 		goto err_eeprom;
-	setup_timer(&adapter->watchdog_timer, &igb_watchdog,
+	setup_timer(&adapter->watchdog_timer, igb_watchdog,
 	            (unsigned long) adapter);
-	setup_timer(&adapter->phy_info_timer, &igb_update_phy_info,
+	setup_timer(&adapter->phy_info_timer, igb_update_phy_info,
 	INIT_WORK(&adapter->reset_task, igb_reset_task);
diff --git a/drivers/net/ioc3-eth.c b/drivers/net/ioc3-eth.c
index 0b3f6df..c8ee8d2 100644
--- a/drivers/net/ioc3-eth.c
+++ b/drivers/net/ioc3-eth.c
@@ -827,7 +827,7 @@ static void ioc3_mii_start(struct ioc3_private *ip)
 	ip->ioc3_timer.expires = jiffies + (12 * HZ)/10;  /* 1.2 sec. */
 	ip->ioc3_timer.data = (unsigned long) ip;
-	ip->ioc3_timer.function = &ioc3_timer;
+	ip->ioc3_timer.function = ioc3_timer;
 	add_timer(&ip->ioc3_timer);
diff --git a/drivers/net/ixgb/ixgb_main.c b/drivers/net/ixgb/ixgb_main.c
index 45fc89b..33c4ffe 100644
--- a/drivers/net/ixgb/ixgb_main.c
+++ b/drivers/net/ixgb/ixgb_main.c
@@ -470,7 +470,7 @@ ixgb_probe(struct pci_dev *pdev, const struct pci_device_id *ent)
 	adapter->part_num = ixgb_get_ee_pba_number(&adapter->hw);
-	adapter->watchdog_timer.function = &ixgb_watchdog;
+	adapter->watchdog_timer.function = ixgb_watchdog;
 	adapter->watchdog_timer.data = (unsigned long)adapter;
 	INIT_WORK(&adapter->tx_timeout_task, ixgb_tx_timeout_task);
diff --git a/drivers/net/ixgbe/ixgbe_main.c b/drivers/net/ixgbe/ixgbe_main.c
index 18163e3..5e4dc1b0 100644
--- a/drivers/net/ixgbe/ixgbe_main.c
+++ b/drivers/net/ixgbe/ixgbe_main.c
@@ -6730,7 +6730,7 @@ static int __devinit ixgbe_probe(struct pci_dev *pdev,
 	 * which might start the timer
 	init_timer(&adapter->sfp_timer);
-	adapter->sfp_timer.function = &ixgbe_sfp_timer;
+	adapter->sfp_timer.function = ixgbe_sfp_timer;
 	adapter->sfp_timer.data = (unsigned long) adapter;
 	INIT_WORK(&adapter->sfp_task, ixgbe_sfp_task);
@@ -6862,7 +6862,7 @@ static int __devinit ixgbe_probe(struct pci_dev *pdev,
 		hw->mac.ops.disable_tx_laser(hw);
-	adapter->watchdog_timer.function = &ixgbe_watchdog;
+	adapter->watchdog_timer.function = ixgbe_watchdog;
 	INIT_WORK(&adapter->reset_task, ixgbe_reset_task);
diff --git a/drivers/net/ixgbevf/ixgbevf_main.c b/drivers/net/ixgbevf/ixgbevf_main.c
index 918c003..5d3c869 100644
--- a/drivers/net/ixgbevf/ixgbevf_main.c
+++ b/drivers/net/ixgbevf/ixgbevf_main.c
@@ -3426,7 +3426,7 @@ static int __devinit ixgbevf_probe(struct pci_dev *pdev,
-	adapter->watchdog_timer.function = &ixgbevf_watchdog;
+	adapter->watchdog_timer.function = ixgbevf_watchdog;
 	INIT_WORK(&adapter->reset_task, ixgbevf_reset_task);
diff --git a/drivers/net/mac8390.c b/drivers/net/mac8390.c
index 3832fa4..f84f5e6 100644
--- a/drivers/net/mac8390.c
+++ b/drivers/net/mac8390.c
@@ -562,19 +562,19 @@ static int __init mac8390_initdev(struct net_device *dev,
 		case ACCESS_16:
 			/* 16 bit card, register map is reversed */
-			ei_status.reset_8390 = &mac8390_no_reset;
-			ei_status.block_input = &slow_sane_block_input;
-			ei_status.block_output = &slow_sane_block_output;
-			ei_status.get_8390_hdr = &slow_sane_get_8390_hdr;
+			ei_status.reset_8390 = mac8390_no_reset;
+			ei_status.block_input = slow_sane_block_input;
+			ei_status.block_output = slow_sane_block_output;
+			ei_status.get_8390_hdr = slow_sane_get_8390_hdr;
 			ei_status.reg_offset = back4_offsets;
 			break;
 		case ACCESS_32:
 			/* 32 bit card, register map is reversed */
-			ei_status.block_input = &sane_block_input;
-			ei_status.block_output = &sane_block_output;
-			ei_status.get_8390_hdr = &sane_get_8390_hdr;
+			ei_status.block_input = sane_block_input;
+			ei_status.block_output = sane_block_output;
+			ei_status.get_8390_hdr = sane_get_8390_hdr;
 			access_bitmode = 1;
 			break;
@@ -586,19 +586,19 @@ static int __init mac8390_initdev(struct net_device *dev,
 		 * but overwrite system memory when run at 32 bit.
 		 * so we run them all at 16 bit.
 		break;
 	case MAC8390_CABLETRON:
 		/* 16 bit card, register map is short forward */
 		ei_status.reg_offset = fwrd2_offsets;
 		break;
@@ -606,19 +606,19 @@ static int __init mac8390_initdev(struct net_device *dev,
 	case MAC8390_KINETICS:
 		/* 16 bit memory, register map is forward */
 		/* dayna and similar */
-		ei_status.block_input = &dayna_block_input;
-		ei_status.block_output = &dayna_block_output;
-		ei_status.get_8390_hdr = &dayna_get_8390_hdr;
+		ei_status.block_input = dayna_block_input;
+		ei_status.block_output = dayna_block_output;
+		ei_status.get_8390_hdr = dayna_get_8390_hdr;
 		ei_status.reg_offset = fwrd4_offsets;
 		break;
 	case MAC8390_INTERLAN:
-		ei_status.reset_8390 = &interlan_reset;
+		ei_status.reset_8390 = interlan_reset;
 		break;
diff --git a/drivers/net/natsemi.c b/drivers/net/natsemi.c
index a6033d4..2fd3963 100644
--- a/drivers/net/natsemi.c
+++ b/drivers/net/natsemi.c
@@ -1570,7 +1570,7 @@ static int netdev_open(struct net_device *dev)
 	np->timer.expires = round_jiffies(jiffies + NATSEMI_TIMER_FREQ);
 	np->timer.data = (unsigned long)dev;
-	np->timer.function = &netdev_timer; /* timer handler */
+	np->timer.function = netdev_timer; /* timer handler */
 	return 0;
diff --git a/drivers/net/pci-skeleton.c b/drivers/net/pci-skeleton.c
index 56f3fc4..8dd0343 100644
--- a/drivers/net/pci-skeleton.c
+++ b/drivers/net/pci-skeleton.c
@@ -1125,7 +1125,7 @@ static int netdrv_open(struct net_device *dev)
 	init_timer(&tp->timer);
 	tp->timer.expires = jiffies + 3 * HZ;
 	tp->timer.data = (unsigned long) dev;
-	tp->timer.function = &netdrv_timer;
+	tp->timer.function = netdrv_timer;
 	add_timer(&tp->timer);
 	DPRINTK("EXIT, returning 0\n");
diff --git a/drivers/net/pcmcia/3c574_cs.c b/drivers/net/pcmcia/3c574_cs.c
index 9b319be..042f677 100644
--- a/drivers/net/pcmcia/3c574_cs.c
+++ b/drivers/net/pcmcia/3c574_cs.c
@@ -707,7 +707,7 @@ static int el3_open(struct net_device *dev)
 	tc574_reset(dev);
-	lp->media.function = &media_check;
+	lp->media.function = media_check;
 	lp->media.data = (unsigned long) dev;
 	lp->media.expires = jiffies + HZ;
 	add_timer(&lp->media);
diff --git a/drivers/net/pcmcia/3c589_cs.c b/drivers/net/pcmcia/3c589_cs.c
index 1c534f3..7f2baf5 100644
--- a/drivers/net/pcmcia/3c589_cs.c
+++ b/drivers/net/pcmcia/3c589_cs.c
@@ -538,7 +538,7 @@ static int el3_open(struct net_device *dev)
     tc589_reset(dev);
     init_timer(&lp->media);
diff --git a/drivers/net/pcmcia/axnet_cs.c b/drivers/net/pcmcia/axnet_cs.c
index e97f151..3f61fde 100644
--- a/drivers/net/pcmcia/axnet_cs.c
+++ b/drivers/net/pcmcia/axnet_cs.c
@@ -356,10 +356,10 @@ static int axnet_config(struct pcmcia_device *link)
     ei_status.tx_start_page = AXNET_START_PG;
     ei_status.rx_start_page = AXNET_START_PG + TX_PAGES;
     ei_status.stop_page = AXNET_STOP_PG;
-    ei_status.reset_8390 = &axnet_reset_8390;
-    ei_status.get_8390_hdr = &get_8390_hdr;
-    ei_status.block_input = &block_input;
-    ei_status.block_output = &block_output;
+    ei_status.reset_8390 = axnet_reset_8390;
+    ei_status.get_8390_hdr = get_8390_hdr;
+    ei_status.block_input = block_input;
+    ei_status.block_output = block_output;
     if (inb(dev->base_addr + AXNET_TEST) != 0)
 	info->flags |= IS_AX88790;
@@ -530,7 +530,7 @@ static int axnet_open(struct net_device *dev)
     info->link_status = 0x00;
     init_timer(&info->watchdog);
-    info->watchdog.function = &ei_watchdog;
+    info->watchdog.function = ei_watchdog;
     info->watchdog.data = (u_long)dev;
     info->watchdog.expires = jiffies + HZ;
     add_timer(&info->watchdog);
diff --git a/drivers/net/pcmcia/pcnet_cs.c b/drivers/net/pcmcia/pcnet_cs.c
index 1815b26..5ad42e0 100644
--- a/drivers/net/pcmcia/pcnet_cs.c
+++ b/drivers/net/pcmcia/pcnet_cs.c
@@ -624,7 +624,7 @@ static int pcnet_config(struct pcmcia_device *link)
     ei_status.name = "NE2000";
     ei_status.word16 = 1;
-    ei_status.reset_8390 = &pcnet_reset_8390;
+    ei_status.reset_8390 = pcnet_reset_8390;
     if (info->flags & (IS_DL10019|IS_DL10022))
 	mii_phy_probe(dev);
@@ -957,7 +957,7 @@ static int pcnet_open(struct net_device *dev)
     info->phy_id = info->eth_phy;
@@ -1341,9 +1341,9 @@ static int setup_dma_config(struct pcmcia_device *link, int start_pg,
     ei_status.stop_page = stop_pg;
     /* set up block i/o functions */
-    ei_status.get_8390_hdr = &dma_get_8390_hdr;
-    ei_status.block_input = &dma_block_input;
-    ei_status.block_output = &dma_block_output;
+    ei_status.get_8390_hdr = dma_get_8390_hdr;
+    ei_status.block_input = dma_block_input;
+    ei_status.block_output = dma_block_output;
     return 0;
@@ -1489,9 +1489,9 @@ static int setup_shmem_window(struct pcmcia_device *link, int start_pg,
     ei_status.stop_page = start_pg + ((req.Size - offset) >> 8);
-    ei_status.get_8390_hdr = &shmem_get_8390_hdr;
-    ei_status.block_input = &shmem_block_input;
-    ei_status.block_output = &shmem_block_output;
+    ei_status.get_8390_hdr = shmem_get_8390_hdr;
+    ei_status.block_input = shmem_block_input;
+    ei_status.block_output = shmem_block_output;
     info->flags |= USE_SHMEM;
     return 0;
diff --git a/drivers/net/pcmcia/smc91c92_cs.c b/drivers/net/pcmcia/smc91c92_cs.c
index cc7a357..3d1c549 100644
--- a/drivers/net/pcmcia/smc91c92_cs.c
+++ b/drivers/net/pcmcia/smc91c92_cs.c
@@ -296,7 +296,7 @@ static const struct net_device_ops smc_netdev_ops = {
 	.ndo_tx_timeout 	= smc_tx_timeout,
 	.ndo_set_config 	= s9k_config,
 	.ndo_set_multicast_list = set_rx_mode,
-	.ndo_do_ioctl		= &smc_ioctl,
+	.ndo_do_ioctl		= smc_ioctl,
 	.ndo_change_mtu		= eth_change_mtu,
 	.ndo_set_mac_address 	= eth_mac_addr,
 	.ndo_validate_addr	= eth_validate_addr,
@@ -1117,7 +1117,7 @@ static int smc_open(struct net_device *dev)
     smc_reset(dev);
     init_timer(&smc->media);
-    smc->media.function = &media_check;
+    smc->media.function = media_check;
     smc->media.data = (u_long) dev;
     smc->media.expires = jiffies + HZ;
     add_timer(&smc->media);
diff --git a/drivers/net/rrunner.c b/drivers/net/rrunner.c
index e26e107..e68c941 100644
--- a/drivers/net/rrunner.c
+++ b/drivers/net/rrunner.c
@@ -1245,7 +1245,7 @@ static int rr_open(struct net_device *dev)
 	init_timer(&rrpriv->timer);
 	rrpriv->timer.expires = RUN_AT(5*HZ);           /* 5 sec. watchdog */
 	rrpriv->timer.data = (unsigned long)dev;
-	rrpriv->timer.function = &rr_timer;               /* timer handler */
+	rrpriv->timer.function = rr_timer;               /* timer handler */
 	add_timer(&rrpriv->timer);
diff --git a/drivers/net/sh_eth.c b/drivers/net/sh_eth.c
index 79fd02b..a812efc 100644
--- a/drivers/net/sh_eth.c
+++ b/drivers/net/sh_eth.c
@@ -1031,7 +1031,7 @@ static int sh_eth_phy_init(struct net_device *ndev)
 	mdp->duplex = -1;
 	/* Try connect to PHY */
-	phydev = phy_connect(ndev, phy_id, &sh_eth_adjust_link,
+	phydev = phy_connect(ndev, phy_id, sh_eth_adjust_link,
 				0, PHY_INTERFACE_MODE_MII);
 		dev_err(&ndev->dev, "phy_connect failed\n");
diff --git a/drivers/net/sis900.c b/drivers/net/sis900.c
index bbbded7..ffdd859 100644
--- a/drivers/net/sis900.c
+++ b/drivers/net/sis900.c
@@ -1042,7 +1042,7 @@ sis900_open(struct net_device *net_dev)
 	init_timer(&sis_priv->timer);
 	sis_priv->timer.expires = jiffies + HZ;
 	sis_priv->timer.data = (unsigned long)net_dev;
-	sis_priv->timer.function = &sis900_timer;
+	sis_priv->timer.function = sis900_timer;
 	add_timer(&sis_priv->timer);
 	return 0;
diff --git a/drivers/net/sunbmac.c b/drivers/net/sunbmac.c
index 618643e..0a6a5ce 100644
--- a/drivers/net/sunbmac.c
+++ b/drivers/net/sunbmac.c
@@ -617,7 +617,7 @@ static void bigmac_begin_auto_negotiation(struct bigmac *bp)
 	bp->timer_ticks = 0;
 	bp->bigmac_timer.expires = jiffies + (12 * HZ) / 10;
 	bp->bigmac_timer.data = (unsigned long) bp;
-	bp->bigmac_timer.function = &bigmac_timer;
+	bp->bigmac_timer.function = bigmac_timer;
 	add_timer(&bp->bigmac_timer);
diff --git a/drivers/net/sundance.c b/drivers/net/sundance.c
index 2678588..3fa9497 100644
--- a/drivers/net/sundance.c
+++ b/drivers/net/sundance.c
@@ -874,7 +874,7 @@ static int netdev_open(struct net_device *dev)
 	np->timer.expires = jiffies + 3*HZ;
 	/* Enable interrupts by setting the interrupt mask. */
diff --git a/drivers/net/sunhme.c b/drivers/net/sunhme.c
index d96431e..45f315e 100644
--- a/drivers/net/sunhme.c
+++ b/drivers/net/sunhme.c
@@ -1409,7 +1409,7 @@ force_link:
 	hp->timer_ticks = 0;
 	hp->happy_timer.expires = jiffies + (12 * HZ)/10;  /* 1.2 sec. */
 	hp->happy_timer.data = (unsigned long) hp;
-	hp->happy_timer.function = &happy_meal_timer;
+	hp->happy_timer.function = happy_meal_timer;
 	add_timer(&hp->happy_timer);
diff --git a/drivers/net/sunlance.c b/drivers/net/sunlance.c
index 8dcb858..2cf84e5 100644
--- a/drivers/net/sunlance.c
+++ b/drivers/net/sunlance.c
@@ -1483,7 +1483,7 @@ no_link_test:
 	if (register_netdev(dev)) {
 		printk(KERN_ERR "SunLance: Cannot register device.\n");
diff --git a/drivers/net/tehuti.c b/drivers/net/tehuti.c
index d808f95..3128d6a 100644
--- a/drivers/net/tehuti.c
+++ b/drivers/net/tehuti.c
@@ -92,7 +92,7 @@ static void bdx_rx_free(struct bdx_priv *priv);
 static void bdx_tx_free(struct bdx_priv *priv);
 /* Definitions needed by bdx_probe */
-static void bdx_ethtool_ops(struct net_device *netdev);
+static void bdx_set_ethtool_ops(struct net_device *netdev);
  *    Print Info                                                         *
@@ -2005,7 +2005,7 @@ bdx_probe(struct pci_dev *pdev, const struct pci_device_id *ent)
 		ndev->netdev_ops = &bdx_netdev_ops;
 		ndev->tx_queue_len = BDX_NDEV_TXQ_LEN;
-		bdx_ethtool_ops(ndev);	/* ethtool interface */
+		bdx_set_ethtool_ops(ndev);	/* ethtool interface */
 		/* these fields are used for info purposes only
 		 * so we can have them same for all ports of the board */
@@ -2410,10 +2410,10 @@ static void bdx_get_ethtool_stats(struct net_device *netdev,
- * bdx_ethtool_ops - ethtool interface implementation
+ * bdx_set_ethtool_ops - ethtool interface implementation
  * @netdev
 	static const struct ethtool_ops bdx_ethtool_ops = {
 		.get_settings = bdx_get_settings,
diff --git a/drivers/net/tlan.c b/drivers/net/tlan.c
index ccee3ed..0564ca0 100644
--- a/drivers/net/tlan.c
+++ b/drivers/net/tlan.c
@@ -393,7 +393,7 @@ TLan_SetTimer( struct net_device *dev, u32 ticks, u32 type )
 			spin_unlock_irqrestore(&priv->lock, flags);
 		return;
-	priv->timer.function = &TLan_Timer;
+	priv->timer.function = TLan_Timer;
 	if (!in_irq())
@@ -1453,7 +1453,7 @@ static u32 TLan_HandleTxEOF( struct net_device *dev, u16 host_int )
 		TLan_DioWrite8( dev->base_addr,
 				TLAN_LED_REG, TLAN_LED_LINK | TLAN_LED_ACT );
 		if ( priv->timer.function == NULL ) {
 			 priv->timer.data = (unsigned long) dev;
 			 priv->timer.expires = jiffies + TLAN_TIMER_ACT_DELAY;
 			 priv->timerSetAt = jiffies;
@@ -1601,7 +1601,7 @@ drop_and_reuse:
@@ -1897,7 +1897,7 @@ static void TLan_Timer( unsigned long data )
 							TLAN_LED_REG, TLAN_LED_LINK );
 				} else  {
 					priv->timer.expires = priv->timerSetAt
diff --git a/drivers/net/tulip/dmfe.c b/drivers/net/tulip/dmfe.c
index 0bc4f30..a9f7d5d 100644
--- a/drivers/net/tulip/dmfe.c
+++ b/drivers/net/tulip/dmfe.c
@@ -599,7 +599,7 @@ static int dmfe_open(struct DEVICE *dev)
 	init_timer(&db->timer);
 	db->timer.expires = DMFE_TIMER_WUT + HZ * 2;
 	db->timer.data = (unsigned long)dev;
-	db->timer.function = &dmfe_timer;
+	db->timer.function = dmfe_timer;
 	add_timer(&db->timer);
 	return 0;
diff --git a/drivers/net/tulip/uli526x.c b/drivers/net/tulip/uli526x.c
index 96de582..1dc27a5 100644
--- a/drivers/net/tulip/uli526x.c
+++ b/drivers/net/tulip/uli526x.c
@@ -480,7 +480,7 @@ static int uli526x_open(struct net_device *dev)
 	db->timer.expires = ULI526X_TIMER_WUT + HZ * 2;
-	db->timer.function = &uli526x_timer;
+	db->timer.function = uli526x_timer;
 	return 0;
diff --git a/drivers/net/tulip/winbond-840.c b/drivers/net/tulip/winbond-840.c
index 66d41cf..f0b2310 100644
--- a/drivers/net/tulip/winbond-840.c
+++ b/drivers/net/tulip/winbond-840.c
@@ -662,7 +662,7 @@ static int netdev_open(struct net_device *dev)
 	return 0;
 out_err:
diff --git a/drivers/net/wan/lmc/lmc_main.c b/drivers/net/wan/lmc/lmc_main.c
index e2c6f7f..43af85b 100644
--- a/drivers/net/wan/lmc/lmc_main.c
+++ b/drivers/net/wan/lmc/lmc_main.c
@@ -1105,7 +1105,7 @@ static int lmc_open(struct net_device *dev)
     init_timer (&sc->timer);
     sc->timer.expires = jiffies + HZ;
     sc->timer.data = (unsigned long) dev;
-    sc->timer.function = &lmc_watchdog;
+    sc->timer.function = lmc_watchdog;
     add_timer (&sc->timer);
     lmc_trace(dev, "lmc_open out");
diff --git a/drivers/net/wd.c b/drivers/net/wd.c
index eb72c67..f1549ff 100644
--- a/drivers/net/wd.c
+++ b/drivers/net/wd.c
@@ -342,10 +342,10 @@ static int __init wd_probe1(struct net_device *dev, int ioaddr)
 	printk(" %s, IRQ %d, shared memory at %#lx-%#lx.\n",
 		   model_name, dev->irq, dev->mem_start, dev->mem_end-1);
-	ei_status.reset_8390 = &wd_reset_8390;
-	ei_status.block_input = &wd_block_input;
-	ei_status.block_output = &wd_block_output;
-	ei_status.get_8390_hdr = &wd_get_8390_hdr;
+	ei_status.reset_8390 = wd_reset_8390;
+	ei_status.block_input = wd_block_input;
+	ei_status.block_output = wd_block_output;
+	ei_status.get_8390_hdr = wd_get_8390_hdr;
 	dev->netdev_ops = &wd_netdev_ops;
 	NS8390_init(dev, 0);
diff --git a/drivers/net/wireless/ray_cs.c b/drivers/net/wireless/ray_cs.c
index 3bd9cf7..d91a831 100644
--- a/drivers/net/wireless/ray_cs.c
+++ b/drivers/net/wireless/ray_cs.c
@@ -604,7 +604,7 @@ static int dl_startup_params(struct net_device *dev)
 	/* Start kernel timer to wait for dl startup to complete. */
 	local->timer.expires = jiffies + HZ / 2;
 	local->timer.data = (long)local;
-	local->timer.function = &verify_dl_startup;
+	local->timer.function = verify_dl_startup;
 	add_timer(&local->timer);
 	dev_dbg(&link->dev,
 	      "ray_cs dl_startup_params started timer for verify_dl_startup\n");
@@ -1981,12 +1981,12 @@ static irqreturn_t ray_interrupt(int irq, void *dev_id)
 					dev_dbg(&link->dev,
 					      "ray_cs interrupt network \"%s\" start failed\n",
 					      local->sparm.b4.a_current_ess_id);
-					local->timer.function = &start_net;
+					local->timer.function = start_net;
 				} else {
 					dev_dbg(&link->dev,
 					      "ray_cs interrupt network \"%s\" join failed\n",
-					local->timer.function = &join_net;
+					local->timer.function = join_net;
@@ -2454,9 +2454,9 @@ static void authenticate(ray_dev_t *local)
 	del_timer(&local->timer);
 	if (build_auth_frame(local, local->bss_id, OPEN_AUTH_REQUEST)) {
 	} else {
-		local->timer.function = &authenticate_timeout;
+		local->timer.function = authenticate_timeout;
 	local->timer.expires = jiffies + HZ * 2;
@@ -2541,7 +2541,7 @@ static void associate(ray_dev_t *local)
 		local->card_status = CARD_ASSOC_FAILED;
 		return;
diff --git a/drivers/net/yellowfin.c b/drivers/net/yellowfin.c
index 4eb67ae..cd1b3dc 100644
--- a/drivers/net/yellowfin.c
+++ b/drivers/net/yellowfin.c
@@ -646,7 +646,7 @@ static int yellowfin_open(struct net_device *dev)
 	init_timer(&yp->timer);
 	yp->timer.expires = jiffies + 3*HZ;
 	yp->timer.data = (unsigned long)dev;
-	yp->timer.function = &yellowfin_timer;				/* timer handler */
+	yp->timer.function = yellowfin_timer;				/* timer handler */
 	add_timer(&yp->timer);
 	return 0;
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
