drivers/net: Move a dereference below a NULL test
If the NULL test is necessary, then the dereference should be moved below
the NULL test.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
type T;
expression E,E1;
identifier i,fld;
statement S;
- T i = E->fld;
+ T i;
... when != E=E1
when != i
if (E == NULL||...) S
+ i = E->fld;
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
drivers/net/bnx2x_link.c | 3 ++-
1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/net/bnx2x_link.c b/drivers/net/bnx2x_link.c
index ed648ac..2ee581a 100644
--- a/drivers/net/bnx2x_link.c
+++ b/drivers/net/bnx2x_link.c
@@ -4212,13 +4212,14 @@ static void bnx2x_turn_off_sf(struct bnx2x *bp, u8 port)
u8 bnx2x_get_ext_phy_fw_version(struct link_params *params, u8 driver_loaded,
u8 *version, u16 len)
- struct bnx2x *bp = params->bp;
+ struct bnx2x *bp;
u32 ext_phy_type = 0;
u32 spirom_ver = 0;
u8 status = 0 ;
if (version == NULL || params == NULL)
return -EINVAL;
+ bp = params->bp;
spirom_ver = REG_RD(bp, params->shmem_base +
offsetof(struct shmem_region, |
+ struct bnx2x *bp;
u32 spirom_ver = 0;
u8 status = 0 ;
return -EINVAL;
+ bp = params->bp;
