drivers/net/ethernet/fujitsu/fmvj18x_cs.c | 34 +++++++++++++++----------------
1 file changed, 17 insertions(+), 17 deletions(-)
diff --git a/drivers/net/ethernet/fujitsu/fmvj18x_cs.c b/drivers/net/ethernet/fujitsu/fmvj18x_cs.c
index cfe7a74..a7139f5 100644
--- a/drivers/net/ethernet/fujitsu/fmvj18x_cs.c
+++ b/drivers/net/ethernet/fujitsu/fmvj18x_cs.c
@@ -99,23 +99,23 @@ static const struct ethtool_ops netdev_ethtool_ops;
card type
-typedef enum { MBH10302, MBH10304, TDK, CONTEC, LA501, UNGERMANN,
+enum cardtype { MBH10302, MBH10304, TDK, CONTEC, LA501, UNGERMANN,
XXX10304, NEC, KME
-} cardtype_t;
driver specific data structure
-typedef struct local_info_t {
+struct local_info {
struct pcmcia_device *p_dev;
long open_time;
uint tx_started:1;
uint tx_queue;
u_short tx_queue_len;
- cardtype_t cardtype;
+ enum cardtype cardtype;
u_short sent;
u_char __iomem *base;
-} local_info_t;
#define MC_FILTERBREAK 64
@@ -232,13 +232,13 @@ static const struct net_device_ops fjn_netdev_ops = {
static int fmvj18x_probe(struct pcmcia_device *link)
- local_info_t *lp;
+ struct local_info *lp;
struct net_device *dev;
dev_dbg(&link->dev, "fmvj18x_attach()\n");
/* Make up a FMVJ18x specific data structure */
- dev = alloc_etherdev(sizeof(local_info_t));
+ dev = alloc_etherdev(sizeof(struct local_info));
if (!dev)
return -ENOMEM;
lp = netdev_priv(dev);
@@ -327,10 +327,10 @@ static int fmvj18x_ioprobe(struct pcmcia_device *p_dev, void *priv_data)
static int fmvj18x_config(struct pcmcia_device *link)
struct net_device *dev = link->priv;
- local_info_t *lp = netdev_priv(dev);
+ struct local_info *lp = netdev_priv(dev);
int i, ret;
unsigned int ioaddr;
char *card_name = "unknown";
u8 *buf;
size_t len;
@@ -584,7 +584,7 @@ static int fmvj18x_setup_mfc(struct pcmcia_device *link)
int i;
/* Allocate a small memory window */
link->resource[3]->flags = WIN_DATA_WIDTH_8|WIN_MEMORY_TYPE_AM|WIN_ENABLE;
@@ -626,7 +626,7 @@ static void fmvj18x_release(struct pcmcia_device *link)
u_char __iomem *tmp;
dev_dbg(&link->dev, "fmvj18x_release\n");
@@ -711,7 +711,7 @@ module_pcmcia_driver(fmvj18x_cs_driver);
static irqreturn_t fjn_interrupt(int dummy, void *dev_id)
struct net_device *dev = dev_id;
unsigned short tx_stat, rx_stat;
@@ -772,7 +772,7 @@ static irqreturn_t fjn_interrupt(int dummy, void *dev_id)
static void fjn_tx_timeout(struct net_device *dev)
- struct local_info_t *lp = netdev_priv(dev);
unsigned int ioaddr = dev->base_addr;
netdev_notice(dev, "transmit timed out with status %04x, %s?\n",
@@ -802,7 +802,7 @@ static void fjn_tx_timeout(struct net_device *dev)
static netdev_tx_t fjn_start_xmit(struct sk_buff *skb,
short length = skb->len;
@@ -874,7 +874,7 @@ static netdev_tx_t fjn_start_xmit(struct sk_buff *skb,
static void fjn_reset(struct net_device *dev)
int i;
@@ -1058,7 +1058,7 @@ static int fjn_config(struct net_device *dev, struct ifmap *map){
static int fjn_open(struct net_device *dev)
struct pcmcia_device *link = lp->p_dev;
pr_debug("fjn_open('%s').\n", dev->name);
@@ -1083,7 +1083,7 @@ static int fjn_open(struct net_device *dev)
static int fjn_close(struct net_device *dev)
unsigned int ioaddr = dev->base_addr; |
